2016 SD Card Reader Installed
  • Replies 49
Who would want to disable car play to have an SD reader ? Just buy a USB SD reader ?
it only doesn't work using the usb ports on the sd card reader box, if you use any other usb port in the truck it works fine.
I installed the new style sd card reader in my console and car play works perfectly from the console. I'm pretty happy with the $14.99 purchase. I had a lot stuff on an sd card from my 2015 truck that I wanted to use. Amazing how much you can store on such a small card. I have 2 movies and hundreds of songs and just using a little over half of the available storage. I am using an LG phone.
What do you mean by "new style"?
By new style, I mean with the sd card reader that the 2016's does not have. It's not really new, but my 2016 didn't have one.
Oh ok - Do you have the part number you installed? I don't have an iPhone to test CarPlay but my Aux in doesn't work on my SD reader.
if he bought the 14.99 one on ebay it's the same one i have and apple car play will not work using it, but you can still use carplay using the other usb ports in your truck.
I did buy the one from ebay for 14.99 and my android car play works fine for me. I am using an lg phone.
yeah i've seen others say the android one works fine, it's just the apple one that does not work
Can you guys confirm whether or not the Aux audio in works? It's not working on mine. That's the only thing I'm missing.
haven't messed with aux since i never use it, but i can put the sd card reader module back in later and check. is there an option in the radio for aux to turn it on and off? i know on my g8 it had the option for that.
this is the factory part that I ordered from gmpartsdirect.com. AUX JACK Part # 22990883 Quantity 1 Amount $56.27 works great.
I didn't see any option on my 2016 SLT AT. I tried it on my coworkers 2017 SLT (no SD module swap), and all I had to do was plug it in and cycle the physical "MEDIA" button on the radio.
Same part number here.
Any chance one (or more) of you guys could try to use your Aux port and tell me if it works with the 22990883 module?
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
