Where can I find??
I'm trying to match the U-bars on my Anzo headlights and I just can't seem to find what I'm looking for. I'm wanting to match the headlight low beams and fog lights. The Phillips reverse/cargo lights are almost dead on. Please help!
The u bar leds on my Anzo headlights. They have a blueish tint at certain angles, then at different angles they have a white tint. Confused on what I'm looking for.
Anything 4500k should be pretty close... But you should try to contact anzo and ask them what kelvin the led in the u bar is.. Then match the bulb to anzo kelvin.
If it's bluish I'd go with a 5500-6000k. 4500 will be closer to yellow.
^^^ what he said. Your Bright white led, 5500k to 6000k are the ones that give you the white/blue light.
Oem kelvin is 4300, which doesn't look yellow at all.
Ok so 6000k it is! Anyone know if Phillips makes the headlight and foglight bulbs? Can't find a listing for them. Unless they are under a different number bulb?!
Anzo uses CFL for those I think. Compact fluorescent lamp. Most angel eyes use the same. It is not leds like the 'glow bar' on my spyder lights which is led.
That said the color temp is around 5000-5500k. You could use a Philips crystal vision halogen bulb which has a Xenon white look for both. Double check with Anzo which bulbs as they may be different from stock and a good bet they are H1 bulbs.
Edit:
Anzo site states h3 for high and h7 for low in Chevy version
GMC is h1 high and h7 low
    B07
    B07
  • Who's Online   5 Members, 1 Anonymous, 990 Guests (See full list)
