2017 6.2L Arriving 2 Weeks Pre-Delivery Checks
Excellent Feedback!
Thanks for the input...this makes a lot of sense. I'll request that they do NOT wash the vehicle. I'm planning on asking if I can have the truck over night. Luckily the dealership is 10 minutes from my house.
I have a 30 mile loop that includes 15 miles of twist back roads and then 15 miles of interstate driving on the way back. My plan is to do this at night so I can get a feel for the LED headlamps what it is like at highway speeds at a time of day that I don't have to sit in traffic.
Regards,
John
I would not do this at night! It's very hard to notice paint issues, scratches, dents or any other type of imperfection. Not that the headlights are going to be a problem, but I'd rather take headlight brightness issues over a paint issues. Headlights are easy to fix.
Pretty covered it. I would not let the dealer wash it or touch it. They reuse the same water over and over again and it is almost guaranteed to leave swirl marks when they are done with it. Most of all your warranty should cover anything mechanical but definitely look it over for any defects in paint or damage. Then look it over again and have someone else look it over after you. If you can, have them bring it out side on a sunny day and then into the shop as different light will show different things. Congrats either way and post of some new pics once you take delivery on it!
I think someotherguy has a good suggestion: Turn off everything while going down the road and listen for air leaks. My driver door has one and it drive me nuts and a driver's door air leak is difficult to fix but easy to hear! IF it's going to leak it will probably be most noticeable at 50 mph or higher especially if it is windy.
Thanks guys.
I am going to ask for the vehicle over night, so I can drive it in darkness and go over the paint in the daylight.
1) Request that they do not wash vehicle
2) Request 91 Octane fuel
3) Overnight test drive
4) All of the pointers above ^^^
Check the roof! I once bought a '99 brand new. Took delivery and went to wash it the next day.
Roof was crushed in. It looked like the damage came from unloading from truck. Dealer fixed
it but had I known, I may have went with another truck.
You won'te regret running 91...truck runs like a racecar!
Follow the break in period. I was told no cruise control for the first 500 miles by my dealer, and due to the distance, I went above 55 mph. Following the no cruise, no hard braking, and no trailers seems to have worked so far, and I figure they put those guidelines in there for a reason.
Enjoy the new truck, and post pictures when you go get it dude!
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
