Advice on leveling kit
I am currently looking to get a leveling kit for my '15 silverado 1500 I have never had a leveling kit before. I was looking at the 2 inch rough country leveling kit. I'm sure I would need an alignment after installing this. Do these kits negatively effect trucks? Do ball joints wear faster? I put on about 25k miles a year so I want it to be pretty reliable.
Here's how it sits currently.
TSzCu4z.jpg?1
TSzCu4z.jpg?1
My dealership sells them. Yes I needed an alignment. Toe was off
I love my 2" rc. Looks perfect and I had it aligned also. Wasn't off much, but I like that peace of mind.
I have had a 2" level since 10k miles and I just replaced both my upper control arms @ 54k, ball joints went bad. Cost me $160, still worth it
I did a 1.5" MotoFab level. Yes, it will need aligned afterwards, my toe was off after the install.
Thank you guys for the information I will probably be getting the rough country with inch level the one that goes on the bottom
Yes, leveling kits will add additional stresses to front end components so they will wear faster but it really depends on a lot of things. I know guys that have run a leveling kit for over 100k miles without having to replace any front end components and I have seen guys install a kit on a brand new truck and then have to do front end work 10k later (these cases are few and far between though so don't let that scare you). Leveling kits are still worth it though. Just a small add on for a drastic improvement in overall looks. And of course, as everyone above has said, an alignment is required if you don't want premature tire wear.
Thanks looking forward to improving the look!
I had mine sitting in my closet for a while I finally installed my rc 2in when I bought new tires and had it aligned, was definitely kicking myself for not doing it sooner!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
