Wireless charging case for Iphone
For those of you who have Iphones, what charging case are you using for the wireless charging pad in your truck?
I didn't think the charging pad worked for iPhones.
It doesn't work with an IPhone unless you add a wireless charging case to the phone. I would like to know from others which cases seem to work well before I order one.
I'm curious too but to me the wireless charging seems fairly useless. If you have an Iphone, chances are you're using carplay which requires your phone to be connected to the USB that will also charge the phone. I suppose if you needed an extra charging case due to being away from a plug in for some time and need it charged that 'might' make sense. Personally I would rather find the highest rated charger case and just plug it into the center console usb and leave it there fully charged to grab if I ever need it.
ive researched this and while I have no idea what case works best, I found out the wireless charging is barely a trickle charge. if your using your phone for gps or something the wireless charging wont keep up, your batt life will still go down
you can buy a slim pad that plugs into the bottom and folds back under your existing case for cheap. just lookup qi charging pad.
I tried the slim pad and it didn't work for me. I now have this one and it works great. It's also the only one recommended by GM for iphones.
https://www.amazon.com/BEZALEL-Latitude-Dual-Mode-Universal-Wireless/dp/B01BCYS66C/ref=sr_1_2?ie=UTF8&qid=1472228375&sr=8-2&keywords=bezalel+qi+wireless+charging+receiver+phone+case+charger+back+case+cover+for+iphone+6
I have looked at this one online but I didn't want to spend the money until I heard from someone else that it works. Thanks man.
QI charging does not work with the GMC, only PowerMat compatiable cases. There are a couple on Amazon that have good reviews and work, I would just search for a GMC compatible case and it should come up.
I have not used one personally so I can't help on which ones are better, I just remember my dealer telling me about one some of the sales guys had purchased on Amazon.
The post by AZ71 is the one I was thinking about as well.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
