Stock Trailer brake controller add on
Skytrekin
So I have a 2016 SLT Sierra, it didn't come with the stock trailer brake controller. The one above the 4x4 control.
Is it possible to buy the parts and add it in? The dealer wants to sell me a aftermarket one and install it under the dash.
This is a highly asked question here.
It can't be added after the fact.
You have to go with an after market one.
I had a P3 in my 2014 it was great.
Correct can't be added. GM sells a plug and play unit from Curt as an option. Comes with a jumper from the junction block under the dash, and it plugs into the brake controller. No wiring or anything needed.
19330154 is the part # and you can see it here at the link: http://www.chevrolet.com/2016-silverado-1500-pickup-truck/accessories.html
Just click on Trailering on the left hand side, the controller is the first picture in the first row of the 8 accessories.
Chevy, GMC, its the same kit for that.
The built in is nice but the aftermarket ones do just as good a job. Even better that GM offers a plug and play kit for those who don't have it!
The factory brake controller can be added but requires bcm custom programming and ipc custom programming and a chassis wire harness for the brake controller module expensive but can be done
At that point you're talking some serious coin though. It's not practical to add it after the fact, just get an after market.
Correct, the factory option is only $250ish installed at the factory, you will exceed that just in the GM controller part alone. Then who is going to program the BCM and the cluster since the dealer cant handle this, GM has specifically stated they will not over-ride factory programming for the VIN of the vehicle to add features the vehicle didn't come with from the factory. Chris White would then be the only other person who can program the BCM and ICP, even then you are taking a chance because once he has it programmed and GM pushes out an update that your truck has to get it will wipe out his programming and put your BCM and IPC back to the current calibration that GM has out for your VIN.
Just go the aftermarket route, cheaper and works just as well.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
