Pained stock rims
Hey guys and gals!
I'm thinking about either plastidipping or black powder coating my rims! Looking to find out if anyone's done it? Preferably with Tungesten truck :)
Thanks! Here's the rim I'm talking about:
If those rims are the ones I am thinking of you will have to plasti dip them. Those rims are a plastic chrome plated face glued to an aluminum rim...you would melt the outer shell if you tried to powder coat them
Hm I know for sure they aren't plastic because I got a little road rash and had to fix that :/
What does everyone think? I photoshopped them black to check it out.
i like the black, but the chrome looks better with your front end...
^^ This, unless color matching the rest/portion of the chrome; the Black doesn't look good,
I was thinking the same thing. I like the rest of my chrome so I think I'll just go with beefier tires. I have a 3" lift now, anyone know what the biggest size I can go is?
