On 8/26/2018 at 7:55 PM, pgamboa said:
I can make this for you. Had a few minutes tonight to put a harness together and test.
PM me for details.
Thank You , I received the plug & plan on putting it in this weekend  :thumbs:
Did anyone else have a hard time getting replies back from wams? Basically I asked the same question room therm as I did here regarding the radio, and the Intella Haul system.
Took me 3 tries but they did eventually reply.
7 hours ago, 6.2Midnight said:
ok, thanks. Do you have a phone number for them by chance?
No phone number unfortunately as I only contacted them via email.
On 7/5/2018 at 10:19 AM, Ravenkeeper said:
Well, after Sunday evening, looks likes I may have to start my <$50 mods all over again.
We’re okay.  I have a broken foot, wife and kids have seatbelt bruises, wife sprained a couple knuckles, and son has a bruised rib or two from the left rear door (during the spin).  I was pinned at both feet, individually.  Left foot was pinned between the E brake and some floorboard, and my right foot was pinned between some floorboard and the center console.  Wife and kids (truely) walked away,, and I “walked away” on a stretcher.
Now to see what insurance says.
http://www.desertnews.com/news/article_f7cae706-7e1e-11e8-aed4-af9e25d44838.html?utm_medium=social&utm_source=email&utm_campaign=user-share
My '15 Mod list was as follows:
- AM/FM Antenna DELETE
- ALL forward-facing white lights ON with HIGHs
- ALL rear-facing white lights ON with Reverse
- Puddle Lights ON with interior lights
--- Key removed from ignition
--- Truck UNLOCKED
--- Interior Lights set to ON
--- Any door opened
- Phone Holder - on dash, left of steering wheel
- Installed CB Radio & Scanner
--- Center Console
--- CB Antenna mounted on right forward stakehole
- 2”x12” Cargo Management Divider in bed
- Tow Hitch Tail/Brake Light
--- Mod’d to Brake Light ONLY
My '18 Mod list is (off to a slow start, but is) as follows:
Was about to do the Puddle lights ON with Doors open mod, but they already do that on their own.
Edited by Ravenkeeper
Corrected the year of the NEW truck
--- Truck UNLOCKED
--- Any door opened
--- Center Console
My '15 Mod list is (off to a slow start, but is) as follows:
What's this mod ???  = KEY REMOVED FROM IGNITION ...
- Puddle Lights ON with interior lights (This is the MOD, the rest is how it's triggered.)
--- Truck UNLOCKED
--- Any door opened
On my '15, if I would remove the key, the interior lights and puddle lights (with this mod) would come on.  Unlock the truck, interior/puddle lights come on.  Turn the interior lights ON, puddle lights come on too.  Open any door, interior/puddle lights come on.
--- Truck UNLOCKED
--- Any door opened
--- Center Console
Bought a new Tow Hitch Tail/Brake Light ($12), since my last one was busted up in the impound yard on my '15, mod'd it to only Brake Light, both tail & brake light elements light up when brake pedal is pressed.
--- Truck UNLOCKED
--- Any door opened
:thumbs:
--- Truck UNLOCKED
--- Any door opened
--- Center Console
Installed a Bully CR-007A Tail/Brake Light Hitch Cover, after I modified it to only be a Brake Light, like I had done with my '15.  Unfortunately, I had to add a 12" 4-wire extension to reach the 4-pin socket.  This little modification could have been as easy as just cutting the brown wire, but I wanted both elements in the bulb to light up when the brakes are applied.  Took a little bit of work, but I was able to get it done.  I'm going to rewrite the instructions and all in my photo album, soon.
On 1/14/2017 at 1:34 PM, A.J. Curtis said:
Was it pretty secured in the lower position before you put in back in the CD slot? I have a tablet mounted below with a home made mount, and this looks like a better solution for me. I'd need it to hold a 7 inch tablet.
Did some budget rock lights.  Hooked it up to my factory upfitter switch I installed for the lightbars.
-9 $ worth of waterproof LEDs
-4 $ Waterproof Sleeves
-3 $ Tube of silicone
-2 $ Stainless steel metal Ties.
-20 $ 18G wire
- 9 $ Waterproof connectors (so I can remove the wheel liners)
-7 $ Wire loom
Made the harnesses and ran them to the back but Holding off mounting the LEDs untill I order some rear liners since mine Didn't come with them from factory and I don't want to drill into the metal to mount them.
Pictures make them look much more blue than they actually are.
Frame plugs ($12) that came in the mail yesterday, so the kids and I put them in this morning.
Right Side:
Left Side:
Right Side:
Left Side:
Are those the factory wheel liners? They look the same felt material that the fronts are made of.  I've been trying to get some people to post pics of them and the aftermarkets to compare how far they come down.  I was hoping they would drop down another few inches to cover up the frame.  Any chance you take a picture look up at the where the liner and box meet? Any chance of hiding a LED strip there without it showing the actual strips?
    1981dustin
    1981dustin
  • Who's Online   2 Members, 0 Anonymous, 1,420 Guests (See full list)
