Am I the only one who has a hellish time getting those diodes in? One always goes good, the other no way lol
I was having an issue getting the diode to get in enough. I ended up trying to push it through the coating higher up so it would get a good connection lol
Will do, thanks.
Yep. With my HMI Unlocked, I have a camera icon on my radio screen. I can access this camera anytime, including while in Drive. It has a 25 second timer on it. I had to jump the run/crank voltage in the connector so that it is powered all the time (since the default operation is to pull voltage from the reverse trigger signal)
The amount of space in these pin cavities are very tight. Try a different corner within the slot. Also, if doing the cargo Lamp/Reverse diode, try to make the 90° bends before insertion. I have also had luck with trimming some of the diode ends off (1/4”). Good Luck!
Phil,
   Can you contact me off line so I can all you a few questions about this? I'd really appreciate it.
These guys sell a Plug & Play harness for the camera .  I think there price of $50. is a bit high , but that's just My 2 pennies .
Im sure you could make a similar harness & possibly beat there price ???
Edited by PAPER
Yes I can. Just need to find some free time. Been extremely busy the past few days. School back in session this week, etc.
I'm sure I am not the only who will purchase it from you ... :D
I would. My two concerns are, how will this effect the hmi from factory, besides what w just seen in the video?
   Next is, how will this effect my Intella Haul system?
Phil,
   Returned you message...
Got it. I’ll respond tomorrow via computer.
I'm sure I am not the only who will purchase it from you ... [emoji3]
I can make this for you. Had a few minutes tonight to put a harness together and test.
PM me for details.
Ok... so the Intellihaul System, module, harnesses etc, goes inline into the factory equipment. So, there **shouldn’t** be any effect to how that system operates. I say **should’t** because I have yet to have someone with the same scenario, wanting to have their HMI unlocked.
The unlocked HMI provided me with a new camera icon on the main screen as opposed to holding the Back button to activate The Intellihaul System.
I did have to provide constant power to the reverse camera so that it was “always on” so that I could access it while in Drive. I have a jumper harness for this now for clean method instead of wire jumpers.
Since the reverse camera needs the reverse signal to “trigger” the camera, this jumper/harness keeps constant power, thus allowing me to access it anytime.
Once accessed, there is a 25 second timer to where it reverts back to the main screen. I can hit the button again for another 25 second timer.
In addition to the new camera icon, the unlock also gave me a Video button. This button is for the DVD/BluRay Integration that I also did.
I also got Android Auto. My truck only had Car Play. I got Video in Motion... allowing me to watch movies (DVD/BluRay), movies via USB, address input (GPS) all while in Drive. Latest GPS Map too.
Hope this helps.
PM me for details.
Phil,
Does this work if we don't have our HMI unlocked?  If so post the info and I'm sure you'll get some orders!
Phil,
Nope. With the HMI unlocked, I gained the camera icon that allows me to call the camera up.
