Deep Ocean Blue Owners: Help Needed
Agreed. I actually like the look of the 275/65's vs a 305/55 on a 20" wheel option. Gives it more of the look of a stock 2500 with a leveling kit. Plus...275/65's are usually cheaper.
About the only 20" I am considering is the black GMC AT Replicas with a machined face.
  • Replies 30
275's are barely bigger then 265's, I think your truck looks proportional!
Thank you. Mine are 275/65-20. Which fills out the well more.
Honestly, getting rid of that snowplow of a valance makes a huge difference in the overall look of the truck and it looking taller. I'll have the Mazzulla skid on there soon. I already drag mine pulling in and out of fields on the farm and my buddy's hunt camp regularly.
The valance/air dam was 7" tall on my truck. Between the 2" level and removing the plastic, I gained 9" of clearance under the bumper. I was glad I did that on Monday when I drove through a creek to get to a field where we were running beans. The water was about 12" deep with some basketball sized rocks along the banks. Truck made it through without any scraping or damage. I was way more nervous when dad said he was taking my truck back across. Let's just say, he doesn't exactly go easy on his trucks. Haha
2" level
18x9 +12 Black Rhino Lucerne
275/65/18 Mastercraft AXT
ABB199C4-6AD4-4335-8CE7-2056A40613A6_zps
406BD6C2-1A9C-4046-8895-93550E3197A9_zps
Could you post a pic of the front dead center please
Sent from my SM-N920P using Tapatalk
528E7770-A3E3-4846-94C5-962A54F9F64C_zps
Did you paint your bow tie? I was looking for a place that sold them prepainted blue
I painted it myself. Went to the local PPG paint dealer and had them mix the paint and put it in a spray can.
Did the same thing with my wife's Malibu. I sprayed it back in 2013 and it still looks good with no rock chips.
I painted them on the vehicle and covered them with plastic drop cloths.
I was going to cover mine in black vinyl since I usually have some left over from projects at work, but I kind of like that color match.
On the original note, I finally pulled the trigger on some wheels and tires. They should be here in the next few days and I'll be installing the MotoFab leveling kit +2.5/+1 later this week when my buddy has a lift free in his shop.
Wheel/Tire will be
17x8 XD RG1's +0 in Black
295/70/17 Toyo RT
I wanted a machined face but pretty much everything I liked was backordered or the shipping from the people that had it kind of killed the deal.
Just an FYI. EBay has the $100 off $400 deal right now with discount tire direct.
I'm gonna buy some STT Pros, 2 sets of 2 so I can save $200.
Sent from my SM-G930V using Tapatalk
Um that's freaking awesome. Where did you get that skid plate ?
Thanks. I made the bumper skid myself. I also replaced the factory plastic skid plate with the optional aluminum skid plates.
  • 4 weeks later...
  • 2 months later...
That was my problem too. I didn't want to go with all black and I didn't want all silver/chrome although I do like all choices. So I ended up getting the 20x9 XD 820 Grenades in black w/machined face and I must say, I love how they look with the blue.
After A wash 1
20161231 150819[1]
20161231 150818[1]
20x9 XD820
Looks sharp. It looks like a factory option, so you did a great job!
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
