Deep Ocean Blue Owners: Help Needed
Yeah, I know there is a wheel/tire thread and a leveled thread. But thats about 400 pages of mess and there are very few of us who have the Deep Ocean Blue trucks in comparison to other colors.
Post up your AFTERMARKET wheel/tire combo...this is more or less because I am at a roadblock in choosing a wheel finish for the truck and want to see what you all have done and maybe it will cause that dim light bulb to turn on in my head. 17-22" I dont care what you have, I'm more interested in seeing the contrast of the color/finish you chose against the blue. Normally I wouldn't be so picky but this one has me stumped as to what to do.
Top choices are a XD Bully in Grey (available), a Walker Evans Legend (Backordered/In Production with Ultra Wheel) with a machined face and black fake beadlock ring or a Raceline Monster with a machined face (waiting on availability). All 17" and wrapped in a 295/70R17 Terra Grappler since its still available in a D load range.
  • Replies 30
Method NV 17x8.5 +0 offset
Cooper ATP 285/70/17
RC level, 2".
No rubbing.
Lots more pics in my build thread. Should be pics of the black chrome wheels I had on previously as well.
Sent from my SM-G930V using Tapatalk
The color matched trucks looks better with black rims but I think a truck with a chrome front end and handles would look great with chrome rims.
Hence my problem. My truck is identical to Waazoos. Part of me thinks the black gets lost in all of it with the tire/wheelwell etc. Other pics make it just look like crappy lighting. I know...splitting hairs lol.
If I could find a satin silver or even a bronze color, I wouldn't have black wheels. I prefer 5 spoke over 10+ spoke. I don't think it's a bad look (black) but it's just dull in my opinion.
Only chrome I have is on the bumpers. If I had chrome handles and mirrors, I would probably have gone with Chrome wheels or Polished.
I have considered getting a second set though, in chrome, so I can change my look every couple months.
I saw the Method NV in bronze, I really like that look with the DOB as well. That is on my list of possibilities as well.
Everyone puts black wheels on now, and I personally don't like all black because they are kind of hard to see, I like machined/black rims better. I would go with chrome because not many people do chrome anymore
Looking at some of these. Makes me wish I went with a smaller tire, it makes the truck look taller and more proportional
Honestly, getting rid of that snowplow of a valance makes a huge difference in the overall look of the truck and it looking taller. I'll have the Mazzulla skid on there soon. I already drag mine pulling in and out of fields on the farm and my buddy's hunt camp regularly.
275's are barely bigger then 265's, I think your truck looks proportional!
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
