2006 silverado ABS sensor?
When i bought my truck about 10k miles ago every once in a while while i was stopping and almost stopped the ABS wouldn kick in and pedal would pulsate. Now it is to the point it is doing it every time i stop. Can i replace just the sensors? Truck isnt throwing any check lights.
Thanks for any help!
I had this issue, and it turned out to be a bad wheel bearing. Changed out the hub assembly, and it fixed the issue. That could be your problem as well.
Are you guys sure i cant replace just the sensors? i jacked my truck up and the wheel bearings show no sign of being bad. I unplugged the sensors and the bad pedal when stopping quit.
You could try cleaning the mounting surface for the sensors. This has been an issue in the past
