New member from KY (Rally Edition)
Mack_Man
Hello!
My name is Mackenzie and I just recently purchased a white 2015 Rally Edition Silverado.
I traded in my 2010 Camaro SS/RS that I had done quite a bit of work on for the truck. I never drove the Camaro and I have about 35 mile 1 way trip to work and winter coming up I decided it was better to get a truck for the snow and things. I'll miss my Camaro but I have a few small plans for the truck to make it mine (exhaust, leveling kit, and some custom emblems)
Here's my old Camaro
Side Camaro2
Side Camaro
Front Camaro
Here's the new truck!
side
front
wheel
Welcome from KY. What area you located in?
I'm in Winchester, close to Lexington.
Welcome to the group, good looking truck!!
Thanks so much! I'm really enjoying it a lot!! Opens my opportunities for a camper and a boat in the future too which will be nice!
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 258 Guests (See full list)
