Third Brake Light
Toxicgoober
Someone who was following me the other night told me my third brake light wasn't coming on. This is the one on the roof of the cab along with the bed light. My bed light turns on fine, but sure enough the brake light did not illuminate when brake pedal was depressed or when the headlights were activated. Then today I noticed 2 other newer Sierras with the same thing. Is this just how the trucks are? I thought legally you had to have a third brake light.
Sounds like a burnt out bulb. Guessing it's common if you saw a couple others like that.
Did you check the bulb?
Didn't try replacing it yet. Since I've seen so many people around without that light illuminated I wanted to see if y'all new something I didn't. I'll replace it tomorrow. I wonder why these trucks seem to go through the bulbs so fast?
They are typical light bulbs and they burn out. Nothing special. Legal depends on your country and state.
not sure if this your problem, but on my 2008 the under hood fuse box, the large one, had one fuse slot stop working, the 3rd brake light. even thought every other fuse worked fine, they had to replace the whole box. $550.00 plus for the new unit and installation.
I see a lot of euro and Asian cars that have brake lights burned out or not working on vehicles less than 5 years old. It seems to becoming more common now with Ford GM and Chrysler. Hopefully the bulb is burned out. If not, then you will need to start looking at the brake light switches. FYI 1 switch somewhere around the brake pedal will control 2 out of 3 lights, and the other light is controlled by another switch, for redundancy purposes.
I'm new to the forum/ website and recently just bought my new 2016 Chevy Silverado 1500 AND a prior GMC Tech. Your third brake light should turn on period, check the bulb and or fuse. Texas law, you don't need a third brake light, so in Texas if your third brake light is not working then you are still good. I recently installed Sylvania LED 921 on the cargo lights which is 2 of them and 1 for the third brake light. Mines does turn on when I brake so if your truck is under factory warranty then take it in to get checked. Hope this helps.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 648 Guests (See full list)
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
