Time for new tires
Rme2513
I have almost worn out the stock tires on my truck and want a good AT tire either in a 265 70 18 ( 32.5 x 10.5 ) or a 275 70 18 ( 33 x 10.8 ) any One have any suggestions on what is the best without going over board
I recently put on 275/70/18 hankook dynapro at-m. They have been great so far. I've taken them through mud, gravel, rocks, dirt, hills and lots of backroad country hunting trails. They have worked flawlessly. I wish they were more aggressive looking, but that is simply for aesthetic purposes. Overall they are a fantastic tire and priced very well.
I have heard great things about the new Falken Wildpeak At3w's. They look pretty good, and in a 275/70/18 they are a steal from discount tire direct. If you want a more proven tire that has been out for a while, I would recommend the Toyo At2's, but they are much more expensive than the Falkens.
Thanks I have also been looking at the general grabber at2 in the 265 70 they have pretty deep tread just have not heard any thing about them
I'll be upgrading to the BFG KO2 in the 275/70/18 size @ 40k miles. It's a 10-ply E-rated tire, tad bit heavier. But is a true 33"
What's the best? The hardest question to answer in any of the other dozens of threads asking the same question. So much personal opinion and many variables. What's most important? Longevity? Looks? Off road traction? Street driving manners? Quietness? Ect...
The grabbers are a great tire (16/32 tread depth in P rated too), many good reviews on them for a much cheaper price then a BFG and they are studdable and snow rated in many sizes. Cooper AT3 is a great tire too and has one some comparison tests for all around ability on and off road. The ATM's I have heard good things about too as well as the Toyo's (though as noted are expensive almost like the BFG's). Falkens are a new tire I am hearing some good things about but they are more aggressive and a hybrid (think duratracs or cooper pros) not an all terrain.
All depends on what you are looking for, search, there is tons of good info and opinions out there. Also check out other forums when you good search, they help give good ideas too...
An E-rated tire isn't a tad bit heavier than stock it is quite a bit and will have a hit on mpg and performance. Stick with LT C rated or P rated if you aren't towing often near your max or off roading a ton in rough areas prone to flats regularly, your daily drive routes and passengers will thank you.
Tyler
Tyler
i just got studded general grabber at2's for my winters - so far i'm really happy with them - all i've ever had on my '14 (and before that my '89) were bfg muds
As of right now I think I will go with the 265 70 grabber at2 but feel free to keep giving good ideas
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 688 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
