I read the manual and it stated Top Tier gas brands were recommended but no specific octane. Just bought a 2016 LT Suburban with the Luxury package. Previously used just the cheapest regularly (87 octane) gas on my 2008 LTZ.
well if its the luxury package, you should probably use premium gas...
j/k. I would still use regular unleaded just like every other engine that is not a tuned high performance machine.
I'm sure we'll hear from others who swear they get better performance from the premium fuel, so buy whatever you want.
Do NOT be buying up all the Premium fuel I need that stuff!. I like 93 octane from any supplier off the top tier fuel list for my tuned 6.2. Runs like a friggin Banshee and gets awesome gas mileage.......
I ran a lot of E85 through my 14 5.3 and never even considered top tier as being important just bought the cheapest stuff available whether E85 or regular 87 octane. The 5.3 really liked anything that I fed it, but the fuel mileage does suffer a bit on the E85.. I guess that is a BIg advantage in staying with the 5.3 engine if you are on a tight budget..
Edited by MyFavTruck
From the Chevrolet manual, page 9-70; "Use regular unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 87 or higher. Do not use gasoline with an octane rating below 87, as it may cause engine damage and will lower fuel economy". I use 89, but as long as you don't use below 87, no where in the manual does it say the truck will perform better with anything higher.
'Top Tier' is a certification of gasoline and additives, not of octane level.
National brands and larger regional brands will all have the certification. Discount independents may or may not.
http://www.toptiergas.com/
Some don't wish to pay for certification and may have the full package without it.
It's unlikely that a single tank of top tier, or a single tank that isn't would be noticeable to most.
Edited by redwngr
  • 3 weeks later...
It's very important to use the recommended minimum octane in the engine, even today's modern engines with knock sensors. The 5.3L only needs 87 octane but the 6.2L needs 91 octane minimum.
As for using a fuel with a higher octane rating that required, well that's a complicated discussion. Some people believe higher octane fuels burn "slower" and hence will actually reduce performance in a engine that doesn't require higher octane fuel. That's true and not true. For retail pumps fuels, not really true. It is true for racing fuels, though. Racing fuels are not a good idea in your grocery getter!!
Some folks believe there is a difference in heat content (BTUs) between the different grades of octane fuels. And hence, a difference in the power gained in the engine. There is some truth to this, as it turns out. But, the difference is very small. More importantly, it's not always directionally consistent. In other words, with some brands, their high octane has slightly more heat content than their low octane; some brands it's the other way around. And, even within a brand, it will vary seasonally as well as regionally depending which specific refinery he fuel s coming from. So unless you want to carry around a BTU tester, it's virtually impossible to take advantage of the difference.
The octane rating itself will not produce more power in and engine that doesn't need it.
Yet some people are convinced their vehicle runs better on high octant (premium) fuel. BS? May not be. Some brands use more additives in their high octane fuels than the lower octane. Things like detergents to keep the injectors clean, anticorrosion additives, stabilizer to keep the fuel from degrading and vaporizing in the tank, etc. And some vehicles are more sensitive to the fuel and buildup on the injectors. So, by buying the higher octane fuel, you end up getting a higher quality fuel which can be helpful. Which is the point of the top tier fuels. These are higher quality fuels. And that DOES make a difference. At least for some vehicles. No way to know which ones, so buyer beware. But I would rather error on the safe side and only put high quality fuel in my vehicles. Unless your driving a huge number of miles a year, what's it really cost extra? JMHO.
I've been using mostly top tier 87 in my 2016 Suburban but the one thing that has bothered me is the idle being rough. It's not concerning but I am just accustom to perfectly smooth idling vehicles and this is not one of them. I filled with a tank of ethanol free 87 and immediately noticed a smoother idle. I was considering trying a tank of premium ethanol free to see if that makes any difference.
Which tune are you using?
If you have the 5.3 just use 87 Octane if you go to a top tier gas station.
If you have to fill up at some cheap-o no name brand discount gas station, you may want to throw in 89 Octane just to offset the craptacular discount gas. :)
Edited by Driver72
While the 5.3l does state 87 is to be used, most of the data logging on the 5.3l has shown they really should be running 89 or even 91. My 6.2l sees nothing other than 91 or a mix of 100 and 91 to get me to 93/94 octane since Oklahoma doesn't have 93 octane anymore.
Hypertech max energy 2.0 part 2000. Really only bought it because it allows you to set a speed at which the AFM only comes on above. I have the GM Borla catback exh and the AFM at low speed irritates me. The Hypertech has 2 options for tune Premium fuel tune and a Regular fuel tune. I ran the premium fuel tune for about 5000 miles with only 93 octane. Got bored so just changed to regular fuel tune and put in a tank of top tier 87 octane as a test. I am getting an occasional click when in 4V at very light throttle around 58 to 62 mph. Next tank will be top tier 89 octane to see if the occasional click goes away. Looks like the verdict is DO NOT USE 87 OCTANE with a 6.2 no matter what tune you use! Truck has around 11,000 miles on it so figured it was broke in enough to experiment on a bit.
mostly city driving with loooong remote start warmups, the Denali DIC calculates overall average speed so that is why the 39mph average. that always seems to throw people off....
Well, GM does recommend minimum. 91 octane for the 6.2L so no surprise your testing confirmed that. When you say "clicked" are you talking about audible knock, or detonation being picked up on the engine management system. Does the Hypertech let you monitors PIDs like knock?
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
    • Prices on the hi-way are falling daily, $3.66- $3.71, Local has yet to drop, actually some are still going up, $3.87 and up
    • I finally got it to start. It was a mix of a few issues. The frame ground was in bad shape so I ran a new one and cleaned up the area to get a good connection then covered it in rust reformer then bed liner to keep it as clean as possible. The other ground I found that looked suspect was on the frame toward the back of the truck near the bed. I did the same. After pulling the fuse box out from the engine bay I found a couple of wires that looked like at some point mice may have got ahold of it. That was an easy fix. After that i was able to get control power and was able to trace down a few more connections going to the other fuse panels in the cab. After that it finally started up and runs. It sounds like an angry school bus which I can work with. No OBD2 codes, but I think since its set for a long time I should pull the turbo and get it rebuilt or swapped out, but for now im good to go. Thanks for all the advice. It got me on the right track.
