Tire wear
likeschevy
I have a 2016 Silverado LTZ 18 inch tires 3500 miles and the outside edge of both front tires are ragged and worn. Is this just an alignment issue ? it is 4 wheel drive.It is not just more wear but a weird ragged wear never seen anything like this before.
Take back to dealership - check alignment , maybe mad tires .
Sounds like the frequent burnouts are affecting your tires STOP letting the teenager drive your truck unsupervised man................. hahaha I actually noticed this unusual wear pattern on my 2016 Denali with 20's the door tag calls for 32psi front and rear but they look and wear (currently a bit over 8,000 miles) like they are underinflated so I am using 32psi in rear and 35 psi in front. It looks like they are wearing more even now but the factory rubber (GoodYear SRA's) are pretty poor excuses for quality tires anyway. I do not expect to get much over 30,000 miles on this factory set. For whatever reason the 18" and 20" tires regardless of brand do not not produce the great mileage of a 16" tire set.
thanks for the replies it could have been under inflation I agree about the Goodyear tires next set will be something else not sure what tire to go with. no burnouts hahaha
my 2014 chev chewed up its front tires in 20k kilometers, dearlership claimed i should have rotated tires more frequently looked at service advisor and said you service it why didnt you rotate the tires, got the blank look. any ways shifted fronts to back and a front end alignment and no problems since
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
