2014 6.2L 6 speed Trans shifting issues. Slow Sloppy 1-2 shift
Ok, I apologize if this was covered in depth somewhere else but after several searches of the forum I have found no clear answers. So here goes:
I have a 2014 Silverado LTZ with a 6.2L and a 6 speed transmission, 3.42 rear gear ration and stock height tires.
Im experiencing these issues:
1. Slow, sloppy 1-2 WOT shift. It takes so long the engine hits the rev limiter in between shifts and I can tell it does because I have a Borla Atak exhaust on the truck so I hear all the tones that the sock exhaust would normally hide. I want my 1-2 to be lightning quick and firm enough to break the tires loose at WOT. There has to be a way to get this thing to clean up/speed up its shifting.
1b. Another problem with the slow shift is when i'm doing any kind of performance driving with the traction control OFF. I'll go to launch with the intention of doing a burnout and it'll spin through 1st like a champ, (gotta love that 6.2L) but then it goes to shift and the shift is soooooo slow that it gives the tires time to catch traction. Then the 1-2 shift finally happens and it bangs and jerks into 2nd then immediately downshifts back to 1st. it's embarrassing. I bought the 6.2L for a reason, it has the power to spin through 2nd before finally catching traction as the vehicle speed matches wheel speed but it never gets the chance because of the crappy 1-2 shift characteristics.
2. Shift into gears too early under light throttle. Especially when making a left turn, it upshifts and clunks then hunts for gears when I go to accelerate out of the turn.
If anyone has any experience with these issues please chime in. I have 29,XXX miles on the truck so I'm still under warrantee but I am sick of thee issues.
EDIT: upon more reading this morning I've came across TSB # PIP5175B, this sounds "similar" to my problem. How do I get GM to address it??
-David
13419012_10208731113989136_1822323644636
12339321_10207294368551398_4902599041241
12345416_10207294367711377_4416143742296
Hmm, I wonder how long would that "sock exhaust" last.
OK, I would recommend a custom tune. Despite the powerful engine, factory transmission shift tuning is designed for maximum fuel economy and protection of the drivetrain, not great driving sensation. GM will not do much for you, the dealers will not alter the factory tune.
Have you tried driving aggressively in the tow/haul mode to see if you like it better? That mode raises the transmission shift points and will not hurt anything, except the fuel economy.
I would also check with my local dealer if there are any software upgrades for that model year.
The sock is what makes a factory exhaust so quiet. :nono: everyone knows that! For the record, Lets see you type better than me with two sticks like the one on my right hand above. Cut a quad a break :bs::lol:.
ok,ok, seriously tho, have you heard of TSB # PIP5175 ? I think my trans was made in Mexico like the ones that's TSB addresses. And it mentions a mechanical issue inside the trans that gives trouble.
Look on the lower rh portion of the window sticker, its tells you where the transmission was made.
RE:
RE:
I don't have the window sticker, it was lost to the company who did the wheelchair conversion. I have an appointment today to address the possible TSB #PIP5175B
I will update afterwards and let it be known what I find out.
You can get a build sheet from any GM dealer parts department if you give them the VIN. I got a build sheet for a 2001 Chevy van I was thinking about buying. The build sheet may not tell you where certain parts were made, but it will list all standard and optional equipment on your truck, much like the window sticker.
ok, so I didn't realize this but they are going to have to pull the transmission to check out TSB# PIP5157B. I wasn't prepared to leave the truck at the dealers at my last appointment so I've scheduled to have it done next week. it sound like this will be the fix for my issues. i'll keep this thread updated for those of you experiencing the same issues.
  • 2 years later...
    • For some unexplained reason my father wanted a salvage yard. As we were getting the family business off the ground one brother ran the salvage yard. We gathered there when rained out working on pipelines in the eighties to pull parts. Perfectly good running vehicles would come to us simply because they wouldn’t pass emissions inspection. We were able to swap parts and sell some of them. I got a clean old nova with a bad engine. I pulled a perfectly good small block out a Camaro. A father and son project with a rebuilt engine. The son couldn’t get the engine running right. The problem was the spark plugs weren’t gapped. The 90s vehicles probably widened the gap of shade tree do it yourself engine repair. My do it yourself hot rod repair stopped at the 70s. After that my trusted mechanic kept them in running shape.
    • I have an old dental chair in my shop. Something I got for free and apparently it has more than scrap value? People collect them although mine isn't restored or anything. It's visually interesting (1930's Ritter) which is why I like it. And it IS decently comfortable if you kick back.   When a good buddy of mine saw it he said, let me guess, Atlas. It's a conversation piece? As in, you ask the questions, they do the talking?   Where do you hide the jar of teeth?   I would never.
    • Are we talking about the same thing, though? The 7 versus 3 wear metals was from Lakespeed's 3.0-specific oil brand comparison test between AcDelco oil and Mobil ESP. The filter remains a constant so whatever excess particles the AcDelco oil is producing aren't being filtered out.   I'm assuming there's a parallel comparison to be made; IF the filter can filter down those particles, engine life increases, and your graph makes the case that a better filter (lower micron rating) can increase engine life. Introducing fewer particles AND filtering those particles with higher efficiency is the best of all worlds. Good oil, good filter.   Where we may disagree is the "baseline relative engine life". I'm more apt to believe the base engine life value is 200k+ on very average oil and filters, "bulk oil of unknown brand and white-label generic fleet-grade filter, Jiffy Lube"   Going from a 10 micron filter to a 5 micron filter should boost a base 200k to 275k in a vacuum as a single factor alone.   Here's the whatabout: How does regularly changing the oil and filter ahead of recommended schedule influence baseline engine life? Most people aren't going to science the heck out of this stuff or ask about Micron ratings, HTHS, or wear comparison tests at Jiffy Lube. Most of the Jiffy lube techs would say they need to call their tech support line to even try to get an answer.   --   Because we love anecdotes here, when I was fishing for 4.3 parts at a local yard this weekend, ALL of the 4.3 vehicles had well over 200k. I love looking at odometers of junked vehicles. How far did THIS go before landing at the crusher? The ones that still had engines weren't seized. None of them were vehicles I'd consider were Amsoil queens, in fact most of them had some kind of service cling-sticker in the corner of the windshield indicating it probably had very average maintenance services. Even the fresh parts rigs- I'm not sure taking an S/T series to 400k has much value considering the running value of those vehicles was probably somewhere around $1,000. 25+ years is a good run on time alone.   The intake manifold I salvaged had clean and bright pool areas. As expected, I found the fuel lines in the manifold rubbed through, just like mine. I'm guessing the lines on that donor truck started leaking, the truck started running rough, and its owner said that's enough I'm unwilling or can't take it out of service for several days, or spend $1000+ to repair it at a shop, it's simply time for a newer more reliable vehicle (or, more than likely, this is the 2nd, 3rd time this has happened in the truck's lifetime). While I don't count on my Blazer for reliability, the thought of giving it away for parts at certain points during my adventure, and being mentally free from its needs has has crossed my mind. I'd be losing $1500 or so, but I can only make more money; not time.
    • still $4.00 85 oct.
