Exhaust
Hello,
What is something I could purchase that would increase my exhaust sound (slightly) without voiding any warranty/lease? Something that would be a bolt on and inexpensive.
Hello,
Change in exhaust won't void a warranty.
Amazon is a good place to start.
A bolt on system that's not expensive? You'll have to be used then. Since you only want to increase sound by a little then try having the resonator removed. It's basically a 2nd muffler and it's above the rear axle, you see it in if you look in the wheel well.
Cut the muffler out and straight pipe it 50 bucks
Sent from my SAMSUNG-SM-G925A using Tapatalk
Yes leave the resonater and get a muffler delete. Mine sounds awesome. Leave the flapper valve. I cut my valve out but I turned afm off
Sent from my SM-N920P using Tapatalk
Do you have any video, audio clip that you can share? Im really thinking of going that route
Nevermind just found a bunch of clips on youtube Im definitely going that route.
You will not be disappointed. I was worried about doing this. I absolutely love it and 50 bucks and 20 minutes for a great mod. I have no regrets
Service mgr at my nearest GM dealership says otherwise. He could be an idiot though. I'm not sure.
Not to hijack this but does anybody know what size the exhaust is for the 5.3? I dunno if I should pick up 2.5" inlet/outlet or 3" inlet/outlet.
I have the 4.3 v-6, same recommendation? I have a little growl but nothing compared to a v-8...
