check the seal at the fire wall on driver side at the steering column. there is a bulletin about this noise and that seal not being installed correctly from the factory. if this is the issue. it says remove the seal and re install properly. no parts needed.
  • 3 months later...
On 5/27/2019 at 2:49 PM, Beastin said:
I can’t watch the clip you posted but if it’s a ticking noise coming from your footwell while driving then yes! The easiest solution I have come up with since my previously failed attempt with the hose clamp is to buy a can of spray white lithium grease, install the red straw in the spray tip and liberally spray between the steering shaft and steering shaft boot to fill the gap you see in the pic I previously posted. I’ve gone a few days and the noise is completely gone and it’s a super easy non invasive solution. I just wiped off the excess with a rag to give a clean appearance... I’m so happy to have my life back while driving and to know that’s all it takes to cure it when need be. I am still working on a permanent solution and when I get the time I’ll test it out and keep you guys informed on the results.
any updates?  Thanks!
What do you guys think of drilling a small hole through the rubber and the plastic bushing and then adding a zerk fitting?  If I recall the bushing has grooves in it.  When you pump the grease it will be forced around those grooves making a tight seal once again.  The synthetic grease I used is form an old tube my parts man gave me like 15 years ago.  It is industrial and very stick like chewing gum so in bonds to just about anything.  It is rated for high temps, shocks and resits washout.
On 2/24/2017 at 7:32 PM, MOhunter92 said:
Nope, mine was constantly doing it correlating with throttle. More noticeable in v4 mode cruising but it would increase with throttle. Try climbing under your truck and just bang on that driver side cat, it's a long shot but that's what I did
Just curious if your noise stayed gone? I have the same issue in a 19 Tahoe
On 2/24/2017 at 12:10 PM, MOhunter92 said:
Well guys, just got my truck back. The noise is gone, I've tried to get it to it several times and it's not there. The tech and I looked along the entire exhaust and there was no sign of any leaking. What he did do is replace my steering shaft for a funny noise it was making, that's about it. When I was underneath the truck, I hit the driver side cat several times with my fist to see if I could hear anything loose inside it, that's the only thing I did.
I couldn't believe driving it home not hearing a damn rattlesnake coming from my footwell. It might come back, who knows but all I do know is this truck has made the sound since it had a few hundred miles and I have 10K now still doing it until this most recent visit to the dealer. Just thought I would share and tell you guys knock on your driver side cat a little bit and see if that does anything
https://www.tsbsearch.com/Chevrolet/PIP5570A this came out in 2018. I bet the steering shaft is what fixed yours!
On 1/14/2019 at 10:57 PM, Rydog28 said:
Same issue on my 2018 Z71 with 4,000 miles.  Dealership heard the noise but doesn’t have a fix.  I still think it’s exhaust related near the drivers seat.  I’m going to hit that cat  tomorrow to see if it stops.  Very frustrating since my buddies truck sounds perfect.   Any solutions please hit me up.  The random ticking/rattlesnake sound can’t me normal!
2018 same noise as described above...only ticks on throttle and can be heard in v4 or v8 just a different tone what was the fix the steering boot or air leak in cat?
On 25/05/2019 at 3:56 PM, Coledtaylor said:
Is this the same sound everyone is referring too?
What did we agree on the solution being?
The dealer said they fixed it but they didn’t and I’m so sick of this noise!
955DE94E-B3CB-4990-B42A-C6288AC31B00.MOV
Sounds like mine...did you find a fix..it happens every time i accelerate and most noticable when maintaining a cruising speed and lightly pressing throttle happens louder in v4 but continues into v8 only stops when releasing throttle...not impressed
Hey Everyone,
take a look at the above thread (I posted a few photos). I replaced my boot and added grease July 9th, 2020 and no noise since. IMO the issue is where the boot meets the firewall. My factory installed boot had a good amount of white adhesive in certain spots pinching the rubber flaps preventing a proper seal. Caution to those thinking about adding grease with a gun/syringe, adding too much may cause the grease to go behind the firewall!
Best of luck!
  • 2 years later...
On 5/21/2019 at 9:03 PM, Beastin said:
I drive a 2018 Sierra cc SLT 5.3, this is the second new GMC I’ve bought, my first being a 2016 dc SLE 5.3.  After roughly 2000 miles of driving my 2016 I started hearing the DI system “tick” coming through the drivers side foot well, I’m a 10 year diesel tech and my gut told me it was an exhaust leak... after 6 trips to the dealer 6 loaners hp fuel line tsb’s performed and everything exhaust related gone through with a fine thoothed comb this issue was still present. I’m a quiet type of driver most of the time, I enjoy reflecting on what the work day will bring while listening to every sweet sound of a fine working machine while Im driving to work. This noise freaking drove me nuts!!!!!! Finally after 8 months of crossing the 2000 mile mark I had spent hundreds of hours scouring forums and I ran across a guy that had an engineer come to his dealer verify the noise and instruct the replacement of the drivers side exhaust manifold and the steering shaft boot, so I asked my service advisor if he would replace the boot on my truck and he agreed... noise was gone for about a month then came back intermittently.. if it hit a certain bump it would start. I’m now a 35000 miles on my 2018 and the noise has started... after going this long I thought they had updated the boot and fixed the issue!! I am so happy after reading some forums to see that GM has recognized this issue!!  I had found the TSB and read it over earlier this evening and I decided I climb under the hood of my truck and try to find where the defect of the boot is or in other words where the gap was at that is allowing engine noise into the cab, I found that instead of updating to a positive lock seal (lip seal) like found on an engine crankshaft or a rear end pinion seal they used an o ring of sort made into the boot that is roughly .030 larger than the steering shaft WTF!!!!!!! Their update to get you out of warranty was to pack it with lithium grease like you guys are doing and let er bump... good for about 30000 miles. I will include pics of mine inside and out untouched factory condition and you can see the air gap where the lithium grease has give way to mileage and allowed the noise to intrude into the cab.. with all this bad news I believe I have conjured a solution in my discontent, tomorrow I’m going to install a hose clamp around the o ringed portion of the boot where you see the air gap in my pic to effectively shrink the seal to the size it should have been manufactured. I will give an update on the results, good luck to you guys, I feel your pain!
You’re a beautiful soul sir, checked my 2018 Sierra and it’s looser than all hell
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
