Transmission- how hot is too hot?
SULLVERADO
While this was the accepted standard at one point, I'm not sure that holds with today's fluids and trantsmissions?
There are different versions of Dexron VI. Some are conventional/syn blends and others are full synthetic. I would assume GM put the lower grade blend in these trucks.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22474061/gotomsg/22475137.cfm#22475137
Here is a quote from the Orange ($8.95) GM manual:
"OIL TEMPERATURE MEASURED AT CONVERTER OUTLET TO COOLER.
300F is the maximum temperature. (Workhorse says 350F). This is the normal place to install a temperature gauge or signal. The temperature in this location will vary significantly with each vehicle start-up or hill. If the temperature reaches 300F (350F), reduce throttle. To lower the transmission temperature with the transmission in NEUTRAL, run the engine at 1,200 RPM for 2-3 minutes to cool the oil. Do not allow the converter outlet temperature to exceed 300F (350F).
Keep a close check to prevent the engine cooling system from overheating.
300F would be typical of rocking the vehicle in mud, snow, or sand, or a transmission in stall (full throttle, no vehicle movement). When the transmission is in stall, the transmission will develop heat at a rate of one degree per second of stall.
OIL TEMPERATURES MEASURED IN THE SUMP
150F -- Minimum operating temperature for continuous operation. It is possible in low ambient temperature to overcool the transmission with oil to air-type coolers; it is hard to overcool if used in conjunction with oil to water coolers installed in most standard automotive radiators.
190F-200F -- Maximum oil level checking temperature. Beyond this, readings are not reliable because of expansion.
285F -- Maximum sump/oil pan temperatures for short duration such as a long hill climb.
300F -- Metal parts inside the transmission begin to warp and distort in varying degrees, seals melt rapidly, and transmission fluid life is extremely short due to oxidation and distress.
AUTOMATIC TRANSMISSION FLUID OXIDATION Automatic transmission fluid
can provide up to 100,000 miles of service before oxidation occurs under normal operating temperatures of about 170F. Above normal operating temperatures, the oxidation rate doubles (useful life of the fluid is cut in half) with each 20 degree increase in temperature. The approximate life expectancy at various temperatures is a follows:
Degrees F Miles
175 100,000
195 50,000
212 25,000
235 12,000
255 6,000
275 3,000
295 1,500
315 750
335 325
375 80
390 40
415 Less than 30 minutes
After-market temp gauge should be installed in the lower (hot) line entering the lower fitting of the radiator.
After-market external oil to air cooler should be installed in series. The hot oil line should go first through the aftermarket cooler then into the radiator to maintain proper minimum temp of the trans in low ambient temps.
End of GM copy from orange manual.
Hey fellas just wondering how hot is too hot for these transmissions. I have a 2014 reg cab 4.3 work truck that spends 99% of its time off the pavement. I was on my way to work this morning in the woods and I was in 4x4 pushing snow and spinning and the temperature was up to 110 degrees Celsius (230 F) just wondering how hot is too hot and if there was a warning? Thanks
If you're concerned about the fluid oxidizing, you can follow the severe duty service interval in your owners manual. I believe GM recommends changing the fluid at 45k miles in severe duty situations. Don't let people nag you about changing it early. You're the one making the truck payments.
That is not an accurate chart.
That predates dextron, let alone dextron iv
That chart contradicts what's in the quoted part of that manual!
There are different versions of Dexron IV. Some are conventional/syn blends and others are full synthetic. I would assume GM put the lower grade blend in these trucks.
These trucks don't use dexIV.
They're at Dex VI for the 6 speed.
The 8 speed uses Dex HP
Oops I did't notice I flip-flopped letters. Thanks for catching that.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 538 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
