It is amazing how no one here knows anything about what I am trying to do on this entire form
I was wondering if i can swap an 03 rear sway link and suspension from a yukon over to my 03 silverado? Can anyone help with this?
It's not something that could easily be done. In theory, it could be done, but you'd have to do a lot of cutting/welding/machining and other fab, as well as possibly some engineering work to make it happen.
The next question would be - Why?
Because that way I could add the 18" airbag kit so I can lower the truck to hook up to a trailer and raise it to drive off. There is a kit for my truck that provides that however it's like anywhere from 3k-9k. And I can get an 03 Yukon rearmed for $250 from the junk yard. I have the sway bar axle and track bar already. I just need to fix it under their truck.
That's a lot of work and money to try to save yourself a couple minutes to get out of the truck, walk to the back, drop the trailer onto the ball, flip the latch & lock it, hook the wires & safety chains up & crank the jack- you know all the stuff you'll still have to do anyways by dropping the truck down.......
