Got some KO2s today!!
TeamGoose
Got these put on this morning. 275/70/18 and not rubbing. Haven't even put my leveling kit in yet. Does 40 PSI sound about right for these?!?
c2353e194e47df9788518f0bdd130d59.jpgf918eabe4011a050858d96e9cfc7ec2e.jpgb730d669bd6f6b8677dd62d52b28080a.jpgbc3a837e7ac8a9d1b1d37758fc02a12c.jpg
No rubbing at full lock? I was planning on a 2.0 coilover setup, but if I can fit these without that's even better.
Still stock and have all range with no rubbing, thinking of only setting my billstein adjustable shocks in the middle for 1.18" of lift. Leaving some rake, I think it'll still look good and give a better ride.
Was finally able to pry a load / pressure chart on the KO2's (LT "E" 18" versions). Here goes. find your tire size, figure out the weight that you run on them and inflate accordingly. You could always over inflate, but why? You decrease braking ability, traction, etc. Best to use an inflation that more closely matches the load you put on them. That is where the tire OEM has determined the best tire life, best handling, best overall performance, best braking, etc.
BFG KO2 18.pdf
BFG KO2 18.pdf
BFG KO2 18.pdf
BFG KO2 18.pdf
Got these put on this morning. 275/70/18 and not rubbing. Haven't even put my leveling kit in yet. Does 40 PSI sound about right for these?!?c2353e194e47df9788518f0bdd130d59.jpgf918eabe4011a050858d96e9cfc7ec2e.jpgb730d669bd6f6b8677dd62d52b28080a.jpgbc3a837e7ac8a9d1b1d37758fc02a12c.jpg
Nice!!!
attachicon.gifBFG KO2 18.pdf
Can you link me to this? I need info for 276/65-20
And they are killer tires and do a great job for me. I have the same size, 275/70R18 on my 2500. For those on a 1500, 40-45 probably would be more than good enough. I run 55 all the way around on my 2500 (even with snow blade on) and only air up the rear 10 psi more if I will be hauling heavy. But it is 1000 lb heavier than a 1500 right out of the gate. According to the chart, I should be running 55 up front and 65 in rear when fully loaded down. But when empty, I just drop the rear to 55 also. But that flies in the face of what GM says. They want 60 front 70 rear. But that was for the stock tires of the size they had on the pickup, LT265/70R18. And the new ones meet the same load rating pound for pound compared to the stock tires, but do so at 5 psi less. So that is why I don't follow OEM on this one.
Michelin, and by extension BFG which they own, have very good load / pressure charts. I use them religiously on my commercial trucks. Got 447,000 miles out of the last set of 445/50R22.5 tires and they still had 8-9/32 tread left and no uneven wear. Now if we could only get pickup tires to last that long!
I just got on the BFG site and used the contact page and asked them for the load pressure chart for the LT tires in 18". They answered me in about two days and sent the PDF of the chart. You can do the same for the 20's. Just make sure on the contact page that you DO NOT put your vehicle in the location provided. Just leave it blank. Else they will punt the ball back and tell you to use the OEM recommended pressure and not send you the chart.
I just put BFgoodrich KO2s on my truck also. 305/55r/20. They are great tires. I contacted bfgoodrich about what PSI I should run these tires at. After giving them my truck info and tire size they told me 50psi. I drove around for a week with 50psi. They seemed really stiff. Right now I have them at 45psi and they feel A LOT better.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
