Isn't my idea. Goes back about as long as power plants have been moving machines. Oh, and Brian, that LT1 isn't the motor in the current K2's. Just say'n.
Yes it isn't a new concept and it has limited value when comparing vehicles. My point was that drawing conclusions such as, "adding 840 pounds to any ride will make it a slug" is not reasonable based on this formula. I drive a CC 4X4 standard box with the 4.3 and I do not find it "sluggish" in any regard. However if this formula proves that it is rated as a slug then the Duramax CC according to this measure is even more of a slug!
Power to weight ratio has the single largest influence on performance. Goes back to Mr. Newton’s second law of motion. Force = Mass X Acceleration. Power is Force and Mass is weight. Acceleration is the result.
So yes it is the proper tool and yes, in and of itself it is absolutely error free. The catch is always the “in and off itself”. The rule of law is constant but humans muck it up all the time.
True story. I built a 400 hp 4200 lb car that I raced about thirty years ago and I took allot of money from guys with 500 hp 3500 lb cars. Mr. Newton gave them every advantage based on power to weight. But these people mucked it up. Could not drive and could not keep it hooked up. Too much gear. Too heavy on the flywheel. Too little tire. No suspension work. As Ron White says…”ya can’t fix stupid”. Thank you very much for the hundy.
There is also the abstract and subjective ‘feel’ thing. I owned and 64 Malibu SS that would not clear its own shadow. But it sounded powerful and thus felt powerful. 283 one barrel Carter with a Powerglide and a 2.73 open 10 bolt diff. Stone puke. 165 hp I think. But it also had some sweet Headman headers and matching Cherry bomb glass packs than made her sound like she was doing a hundred at twenty five. It was purdy and the girls like it so….
Lastly there is the point of reference thing. If you’ve been driving a 1958 36 HP VW Beetle for a decade even a bicycle feels pretty spunky.
Point is….there is objective and subjective. What it is and what it feels like. If it feels perky to ya. Great. Subjective analysis, check.
If the argument is about the objective physics? Argue that one with Mr. Isaac Newton. I don’t that sort of thing anymore. Retired.
BTW, add 840 lbs. to a setup and it is indeed a slug in comparison. I stand by it. Thank you Isaac.
Edited by Grumpy Bear
I sense by the lecture/font size I have upset you and for this I apologize. Judging by your references to 50's and 60's vehicles we may have similar experiences but have developed different jargon. I find that referring to a vehicle as a slug (especially mine) very negative. Your initial argument suggests that a truck like mine based on "objective" rationale is a slug. I am simply clarifying that the term slug as used here is even more applicable to a 397 hp Duramax. Maybe this is a term like "sick" which has positive and negative interpretations.
Edited by Donstar
V6 Engines last longer then I4 engines.
V8 Engines last longer then V6 engines.
That's mostly what I look at as I high millage all of my vehicles..
If 0-60 or 1/4 mile is your guadge, past experience from my amateur drag racing days was your results may vary. Example my 94 Z28 according to hot rod mag was 14.7 mine did 13.5. My 94 impala ss was 15 according to hot rod mine did 15.50. I wasn't happy with that one.
No no, not upset at all. I write large because I see poorly. LOL. I write and think as I do. Length is the result. If I ever did get upset it wouldn't be in front of a crowd. I do that one on one. No worries.
Absolutely. Different driver. Different track. Different day and the list continues. It's just these sorts of real world things that convince us of our opinions. Thing is, the laws of nature are not opinions. Good thing too. If gravity, for instance, had a different value or worked independently of law this world would be a real funny place.
This seems reasonable.
Is there any reason to think only the 5.3 might be faster than the Car and Driver tests though? The 4.3 might also be faster as well, the ratio of power to weight is certainly the same.
Of course.
Of course.
Given that we all drive on streets where speed is regulated, I'd say 0-60 is about all that matters on performance.
7.3 seconds for the 5.3 vs 8 seconds for the 4.3 (both on regular gas) would seem a pretty irrelevant difference to me.
If I was buying a p/u for personal use I get the single cab and put a 373 rear in it and be a happy camper with the 4.3. on E85.
Rawr, rawr, rawr, 5.3, rawr!
I've got a Airaid MIT tube, only mod on my engine, looking for a 6.2 with the same to race...
No offense, but you should hope you don't find any 6.2s to race, even stock. 4.3s aren't going to beat 5.3s, and 5.3s won't beat 6.2s.
The stock air filter is pretty high air flow already, but you might have a chance on 100% E85!
http://www.gminsidenews.com/forums/f22/lingenfelter-tests-e85-through-new-silverado-119387/
I haven't tried E85 on my 5.3 as yet, but it was definitely noticeable in the 2014 4.3 I had. I wonder if the dealer had E85 in it on the lot when I test drove the 4.3 and that would make a lot of sense. I drove to the dealer in a 5.3l with 315hp/330ft lbs torque. I test drove a 4.3l that would have had 297hp and 330 ft lbs torque on E85, and would have been totally indiscernible from my 2010 5.3l.
Would be a pretty crafty sales tactic for the dealer, so I'm inclined to think they would be smart enough to figure this out.
I love the little 4.3 engine it is much more practical than the larger engines being pushed on people. I would like to get one and lock it into 4 cyl mode permanently and get a Sierra Club sticker on the tailgate keep it green brother...
April Fools! Interesting thought about the 4 cyl mode. It would be great if you could manually switch this feature on and off.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
