LED cubes in fog light location
Dozer466
I just installed some cubes where my fog lights were at. I tested the lights prior to installing them and they worked fine. Now I can't get them to turn on. Any suggestions? Thanks in advance.
Wired properly? LED'S cannot have reverse polarity (positive to negative) have to be ran in-line with their proper polarities
Sent from my SM-N920V using Tapatalk
Pictures as well please been thinking of doing this to mine as well and just flip the wires did that to my dash board led pset up
Sent from my Z981 using Tapatalk
Yes, they are wired properly. I am using the factory fog light switch and did not use a resistor though.
Got it fixed, it was the fuse. The first time I checked the fuse I must have pulled the one next to it for the horn. I appreciate the responses. Have a Merry Christmas!!!!
looks good. what led lamps did you used ??? how much plastic had to be trim ???
Thanks Tahoe.
I used the Rigid Industries SR-M2 lights and the Rigid Industries mounting kit, made specifically for my truck.
http://www.rigidindustries.com/led-lighting/91211
http://www.rigidindustries.com/mounting-options/46517
Zero trimming required! And they look awesome. I have a build thread in the build forum if you're interested in some more pictures of it. Here's a closer picture of them:
Thanks Tahoe.
fog lights - are they all wide / spot / flood / or did you mix them ???? Thank's for info
I wish there was a way to put the clear lens back over the top of the fogs like how the stock ones have. Feel like the lights would be protected, without theyre exposed to anything which could cover up the output. I imagine its a pain to clean that area too
I believe I went with all wide pattern. Considering you can place 4 pods in there, it'd probably be a good idea to mix it up and do two wide and two spot or something. Either way, I'm very happy with them.
thank you - I think I go with fog / driving - two switch's .
    • Kudos? Are any of them desirable? Class leading (in any metric)?
    • Those are great questions, Bill. Our team looked into your VIN and it doesn't appear to have AFM or DFM. Please know, we take the personal and private information of our customers seriously, and we don't recommend posting your full VIN publicly. As for Auto Stop, some vehicles have a button to turn Stop/Start off for one ignition cycle. If the vehicle is equipped with the Stop/Start deactivation switch, you can push the switch to turn off Stop/Start. Stop/Start is turned off when the LED indicator on the switch is not illuminated. If you have any further questions, please visit https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
