Wheel and Tire Question/Help
Hi all. Just a quick question. I have a 2015 Silverado with a 2" Leveling kit. Im looking to buy wheels and tires for it. I want to go with a 275/70/R18 Cooper Discoverer STT Pro tire with the Fuel Beast 18x9 wheel. My question is with just a leveling kit what is the max offset wheel I can run without rubbing?Just curious if a +1 would rub or if I have to run a +12? Thank You!!
Yourr probably going to need more than a 2" level for STT Pro's, possibly actually lift with 70s. I have 275/60R20 duractracs and even with 2" level i had to trim my mudflap another guy pulled back his liner. STT Pro is an even bigger tire i believe than Duratrac.
To answer your question though your if you do just a level (2.5) you may need a negative offset.
Im guessing though. Im flush at +15 still had to trim
No lift is needed to run 275/70/18 KO2s, members on here have pics after install of no rubbing at full lock.
I'd personally say with a 2" leveling kit you'll definitely be fine with a 33" tire.
Our factory tires are +24 offset...so use this and an online calc to figure out. Or just call Fuel and they'll help when ordering the wheels.
27MM for factory 20" and 24MM for 18" factory.
Cool, but he doesnt KO2s
Sent from my SAMSUNG-SM-N910A using Tapatalk
Thanks for the heads up - He doesn't have STT Pros either, he's in the market for tires.
STT Pros just have a deeper tread than Duratracs (20mm I believe compared to 16mm).
275/70/18 is a 33.2" tire, just 1.1" taller than a 275/60/20 (which is a 33.0" tire).
If you aren't going any wider than 275, I think you'd be perfect with a +12 offset.
Yeah but STT Pro is what he wants to buy. Correct tread depth 20mm compared to mine at 16mm but here is exactly how close i was after the level. In reverse the tread pulled down on that corner of the mudflap BAD. I was clear on the liner but it was close as well
After i trimmed .. its still close but its clear no issues.
Im not saying he cant do it with STT Pro but theyre going to fill out a little more than mine do
I run 285/75r18s on stocks with a 2.25" leveling kit. Not problems. Toyo AT 2 Xtremes
Not sure if this helps. But just put the KO2's 285 65 on Stock 18 rims with a 2' RC Level Kit.
NO rubbing at all. A bit rougher of a ride cuz of the 10ply but i love them!
I know OP asked about 18x9. FYI, I spent several weeks on this forum and went with 20x9 MotoMetal 970's +18 offset with Nitto Grappler G2 305/55-20's (the lighter LT version) after installing Bilstein 5100's at highest (1.85") adjustment to level front. I've run over 100 miles and tested full lock on both sides goingn forward and backward. I can positively tell you this configuration is unbeatable! No rub (I did tie back the inside of rear wheel liners to get about 3/4" more space at closest point). Ride with 40lbs is excellent. Tires are very quiet, no tire road noise in cab at any speed, very quiet with windows down.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
