14+ Level kit, 4" lift block & shock extensions
I have some parts for sale. I have a 2" Level kit from rough country. This will only raise the front to even it out with the rear. I have a 4" tapered lift block kit from Rough Country that comes with the u bolts and hardware. I also have ReadyLift Shock extension brackets for anyone who wants to retain the factory shocks OR compensate for shocks that are too short until they get the correct size. All prices are shipped in the US. I will not ship international. Decided to do this at work today since I had some free time but I will have pictures up later today.
2" GM Leveling Lift Kit - Link: RC ----------------------------------- $30
Maxtrac 541500 Rear Shock Extension Brackets ----- $25
4" Rough Country Lift Block (U-Bolts and nuts included) - RC---$45
Lift Block kit from Rough Country that came with their 2.75" level ----BNIB Offer Up (I am not sure how much taller it is than stock but it is slight bigger, maybe an inch and its tapered)
I went to the RC site, what type of lca are these for?
These are for steel lower control arms. Sorry for the delayed response; must of missed the email notification.
Which type, cast steel, or stamped and welded steel?
For those who may not know the difference between the two types for future reference:
OE_GM_1500_16_ControlArmVariations-hires
Good info! Mine are cast steel
Figures, I have stamped & welded....
What were you interested in, the level kit? You sure it won't fit regardless of LCA? It is only a spacer but I'm not sure how the fit differs across the different LCAs
Sent from my SAMSUNG-SM-G935A using Tapatalk
Yes, level kit. I called them, they told me the difference is in length, and clearance. Three was another member here who had a universal set for see, so I went that way. GLWS.
