Ball joint help
Tyler1199
I currently have a upper passenger side ball join that is bad- 2.5" rough country level lift is installed and I'm sure this is the main reason- only 29k miles on truck. Deciding between going ahead and replacing both uppers with OEM alumnium- ball joints are non serviceable. Or replacing them with moog steel control arms with ball joints. - would having a steel Upper and Alumnium lower cause any issues? It seems lowers on the alumnium arms are serviceable.
  • 4 weeks later...
I bellieve someone said the ball joint tapers are different. Might cause a problem with the knuckle if true. I wouldn't risk it.
I would look into aftermarket UCA's that are designed for leveled or lifted trucks, that will address the ball joint issue you had here. I installed Cognito UCA's when I leveled the front. The bolt on ball joints are great when it comes time to replace them.
  • 4 months later...
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
