Took the Fox 2.0 plunge
Vetteran
Just finished putting the cognito UCA (ball joint ones) on my sierra with the fox 2.0. My Goodyear duratrac's fit just fine on stock rims. 265/65r18. I have about 3/4 of an inch clearance at full lock.
Setup looks great, how is it riding one month in?
  • Replies 126
Rides great. There wasn't much of a break in because I had the coilovers installed on my 2010 Silverado for 10k miles.
Just need to get good shocks for the back now. And possibly airbags we'll see.
  • 1 month later...
Here's a couple shots of my set up, I'm running the Fox 2.0's, cognito uca's and 3"maxtrac spindles. I did this set up to alleviate the angles that are associated with leveling kits, side note i had the uca's and fox's for a year and half it was a great improvement from oem, but the new setup is even better. The new setup gave me 4in of total lift and have decent gap between the uca and droop stop. I would say this is a great set up for those that have 2wd. E5344632-34BB-4DD5-A531-F2BD8B7BA66A_zpsDSC_0193_zpsdzsc5kus.jpgDSC_0195_zpsdl8bqd8k.jpg
Can anyone tell me if there is too much pre-load on these 2.0s? Just got these delivered today. I'm counting 40 threads below the collar and everyone else I've seen only has 15-25 at max. I want to adjust before I put on my truck next weekend.
What part number are these? The ones i have didnt have as many threads showing as yours do when i first installed them, you can see below. But on a side note mine where the older part number meant for the steel uca's, i know since then they have changed the part number, had something to with the fact that people with Aluminum or Stamped uca's were not achieving the advertised height out of the box.CADB33BB-01BD-4F74-A442-093169B61776_zps
985-02-018
Pretty sure there's only one part number for them now. How much lift did you net with the coilovers set there?
I have stamped steel arms.
Hmm since when are cognito arms blue?
When you take them a part, drop them off at the local powder coater. Request to have them coated in Bengal Silver and a top coat of Prismatic Powders Hd Teal. That would be how.
985-02-018
I used the P/N: 983-02-086, which is meant for the MY 07-15 with cast steel suspension. When i initially installed them my front fenders measured about 40in then they settled about an 1in to 39in.
10.8" from just above Fox logo to top of pre-load ring where spring sits - from Fox
  • 1 month later...
T
983-02-086 is now discontinued and no longer made by FOX. Just clearing up any confusion :)
  • 2 months later...
is anyone seeing 2in of lift on a crew cab or 2 inches after settling?  I was thinking about putting the motofab .5in block under the shock.
I'm about to pull the trigger and want to do cognito UCA.  Is anyone cutting away the service perch on their truck for these?  Just was taking a look at the instruction manual
its about 8 weeks till my new wheels come in  20x10 -24.  I think the stock 17 will rub.
Any thoughts would be a great help!
I just got off the phone with fox and the dude I spoke with told me that the shocks are not made to be adjusted after buying them for the preload is already set.  adjusting it more for more lift could cause the spring to bind.  As well as for heavier trucks like mine V8 Crew cab that I would only see 1.5 inches of lift out of the box.  I asked about putting a .5 in spacer under to get that full 2 without adjusting the shock but he didnt seem to keen on it.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 431 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
