Took the Fox 2.0 plunge
Vetteran
Is this how it came from Fox? Or did you readjust?
And how much lift is this?
And sounds like Camburg/Dirt King would be the best bet then.
stock for me
  • Replies 126
So for the guys that are running this set up currently, how dramatic a difference are we talking over stock? I've been running the 2.0 set up front and rear for about two years now and am not blown away by the difference.
That being said however, I was one of the lucky ones that purchased and installed during the issue when the pre-load settings were incorrect out of the box (I believe) and subsequently discovered a few months later. I have the correct 018 part number installed for aluminum control arms.
My installer was never able to achieve a level stance. Maybe got a little over an inch so sits slightly nose low. Doesn't look awful but not as good as it could and on road performance is stiff. Rebound when hitting a quick dip at freeway speeds cause a noticeable thump in the front end. Trail performance just seems ok, rough and not absorbing of ruts, rocks, etc but seems to have better control.
I've since done some inquiry with Fox and they informed me that the spec'd 2" to level could be achieved on 2WD not 4WD. In any case, they said I could bring them in to have them checked out to confirm the correct position of the pre load rings, re-valve to soften them up etc but they they have to be off the truck. This means I'd have to re-install my Ranchos, re-align, take the Fox's into their shop, then re-install them and re-align again.
I feel like the peace of mind might be worth it to confirm everything setting wise is correct plus, I'd really like to get the performance out of this set up that it sounds like some of you have gotten. So my original question, should the difference over stock be night and day noticeable?
For my 2014 with Aluminium arms, I got about 2'' of lift and a better ride, but it's still a 4wd truck. My 95' 2wd Silverado does ride better but its 2wd. For myself, the fox 2.0 improved the overall ride, still stiff, but much better. I got the same amount of improvement from changing the stock Goodyear SRA to the Duratrac. My alignment was only slightly off, and it was only a toe adjustment so if you got less lift than me, I wouldn't worry about getting another alignment while waiting for fox. I'd be interested if the updated arms fixed the ride for you. I thought about getting the 2.5's for the rear but the stock ranchos were terrible towing.
I'm going to run the Cognitos with Fox 2.0 because all the other arms I see use a uni ball. I'm sure they are good however my experience with uni balls or heim joints prove that with Midwest winters the corrosion kills them quickly. Does anyone make a "weather proof" uni ???
Also the cognito ball joints appear to be what 2500/3500 trucks use so they should be overkill on a 1500 which suits me fine!
Had some condoms for heim TRE's I had from FFR, can't remember where I got them though.
You would think they would include some kind of rubber "boot" to protect from road dalt etc. Hopefully someone knows what can be done but I'm leaning towards regular ball joint configuration. Plus they are grease able
If you grease frequently and properly you shouldn't have too many problems
You should not grease uniballs...this will cause premature wear/failure.
Uniballs are self lubricating, keep them clean and thats all you need to do! They have PTFE liners. Some use dry graphite lube to keep the squeaks down, Also make sure you get the stainless steel versions if you are replacing them, FK has two different variants.
Just dropped the truck off at shop to get my front and rear 2.0's installed.
OH MY .......
It was worth every penny I just spent -- I should have done this from the start!
Details?
It's a night and day difference from the Rancho shocks we get with Z71--ride home was incredibly smooth and nice. I hit some bumps that I normally hit that are jarring--this time the truck handled them well and didn't bounce me out of my seat. Wife gave me a thumbs up too, which is always a bonus!
I bought the Fox 2.0 coil overs up front and long-tubes in the rear. Cost me $1500 installed from 4 Wheel Parts.
The fox 2.0 rears?
