Dexron VI transmission fluid after 32k miles
truckguy82
  • Replies 70
First let me say I don't know didly squat about this thermostat block; so maybe excuse my ignorance.
But just a thought, could you disconnect the lines, remove the block, then get a small piece of line made up with the proper fittings, and just connect the lines in a loop? Basically just getting rid of the block and putting the trany line in a loop as to where it connected to the block. Or must the block stay?
Anyone know?
Keeping the block is by far the easiest solution
The threads on the screw are not used at all!
I wonder if someone makes a bypass block that you could just swap?
No block but I will make some more of these if they are wanted. PM me
RT
RT
Why don't you post some info? Prices?
  • 3 weeks later...
I changed 4 quarts this past weekned and the fluid coming out of mine looked nice and pink this time. I put 4 quarts of ACDelco fluid back in. I have another 4 quarts on the shelf and will do that at 100k miles unless something makes me think it needs it earlier, fluid color changes.
What mileage are you at now with the first 4 quarts you changed?
Was this the first ever change; just curious, as you said the color was still nice and pink.
Here is the picture.
Trans%20fluid%20Mobil%20jug_zpsswzybv26.
The picture above was the first time I have changed the fluid. I bought the truck with 42K miles on it. I changed the trans fluid the first time at 72k or so miles. This 4 quart was at 75K miles. I just wanted to make sure the fluid was not dark like in the picture. I will change another 4 quarts at 80 or 90K miles.
I'm the same as Cowpie, I change out all fluids before 10k miles. Have done this on all our vehicles. Just makes me feel better. Yes there are vehicles on the road with tons of miles on them that have not had it done. But for me it makes sense to get all the wear in material out and go back with a quality fresh fill of synthetic fluid.
https://youtu.be/HVP0z2hbN90
Sent from my SM-G935T using Tapatalk
Thank you for this video, I've been really wanting to do this mod, but was never exactly sure on what exactly to do. And it seems that people go about different ways to achieve the same result; however your way sure seems the easiest.
Is there a reason you have to flip the brass thermostat plunger around then put the spring in. Why couldn't you just remove the brass plunger and spring ( remove everything) then just put the top back on and put the snap ring back to hold it in place and sealed??
I'm sure there's a reason, I just don't understand.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
