Dexron VI transmission fluid after 32k miles
truckguy82
  • Replies 70
20 to 40 lower temps on 90° weather when idling temps do go to normal temps but come down as soon you start moving some people add a 160 thermostat on the engine that helps with idling temps and some just buy an aftermarket block with no thermostat and add a tru cool with braided lines
Sent from my SM-G935T using Tapatalk
Is there a reason you have to flip the brass thermostat plunger around then put the spring in. Why couldn't you just remove the brass plunger and spring ( remove everything) then just put the top back on and put the snap ring back to hold it in place and sealed??
I'm sure there's a reason, I just don't understand.
I did mine differently i left mine in the open position all the time by adding a piece of 12 gauge solid copper wire and removing the pin in the little brass thermostat
When i did mine i did it so quick that i didnt pay attention to the inside of the block but i think u have to have something between the in and out flow so that the fluid actually goes to the cooler and comes back to the tranny
Yes, OK, Ive looked at it, now I understand, basically you have to plug the middle of the block.
Why did you choose to do it this way as opposed to the way you showed us in the video.
Is this way better than the way you showed us in the video? If so, why is it better?
  • 2 months later...
Ok i did this today with clear 3/8 od tubeing i could only get it deep enough to pull 3.5 qts out. Was pretty dark but still had some red in it at 32k miles. Will repeat again soon.
Follow-up bought a 3/8 od plastic waterline tube was able to get 4 qts this time. Still dark but more red the round 1. Will do 4 more qts. Will repeat ever 30k or so.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
