2016/2017 1500 HID swap
FastWS6TA
Which projector is which in the pics? That top one....... :drool:
The top is the e46 with 35 watt d2s (can/should use d2h) bulbs.
Sent from my SM-N920V using Tapatalk
***Making some focal length adjustments today. More pics tonight. Makes a big improvement compared to the pics I posted yesterday. Stay tuned. Ha
I've been waiting to hear some info on this ever since you posted about it on Facebook and Instagram, I've emailed back and forth with Josh a little bit about it and was waiting to see if the e46 replicas also fit the 17 silverado's. That pic showing the stock projector and the e46 one makes me want to get this done ASAP!
Made some adjustments today to the adapter to compensate for the focal length on the Morimoto bulb being different than the OEM. You can see in the pic that this increased the hotspot. Now it is as large if not larger than the oem projectors. Remember too that I am using a 6500k bulb and the oem is more like 4300 to 4500. Color will therefore be a tad different. 4500 will also give the most brightness as compared to higher Kelvin bulbs. Most we sell are 5500 or 6500 as people are looking for the bluer end of the spectrum.
Top pic is oem
Middle is the 35watt Morimoto
Bottom is 35watt Morimoto but when I didn't have it adjusted to maximize the focal point of the bulb.
If you're a 2016 LTZ Silverado...you should have LED headlights, not HID...just FYI.
Good point. I had forgotten about that. Just been thinking mine weren't as bright as I'd like and got excited. I had them turned down some when it was leveled so maybe I need to go back up some.
Sent from my Pixel XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/topic/192614-tenscourts-2016-ltzz71-ccsb-4wd-silverado/
2016 2500 HD w/halogen (miserable btw), but I can't find OEM LED addons, was at dealer today asking. I was never a fan of HID's found them unreliable and too bright for oncoming traffic. Of course I havent had a set for about 8 years so the technology may have imoroved. I haven't heard whether or not this could work on a 2500.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
