2016/2017 1500 HID swap
FastWS6TA
Have quite a few customers ask about swapping out the 25 watt factory HIDs with 35 or 55 watt Morimoto. We now have a solution for this. An adapter that allows you to easily swap out the factory HIDs and put in your choice of Morimoto HIDs. These aren't on our website yet, but wanted to let folks know that a solution is here.
Simply take out the factory hids by turning 1/4 turn to the left. You then clip on the new adapter base, insert the Morimoto d2h bulb of choice, then screw on the bulb holder cap. This can be done from the back of your headlights without removing from the truck.
Here are some pics. Top pic is a 35 watt Morimoto 6500k HID. Nice color along the cutoff line. Bottom is factory HID.
Sent from my SM-N920V using Tapatalk
Is this for the sierra
Yep.
interested, how much?
Email me at [email protected]. I'll send you a set to try. You can tell me what you think.
Call me curious but... OEM HID's get to full power very fast. This helps for flashing the high beams during the day... how long does it take these kits to get to full power?
It's nice to have options, but the OEM looks better to me. Granted it's only 25w too. Hotspot is bigger and they look brighter. The 6500k seems to wash out and street signs aren't as visible. I love my Morimoto's, but they take about 20 seconds to warm up also.
Now if there was a kit for the 16/17 to retro some FXR's or D2S to get rid of that stock projector.....
Agreed on the FXR. Ha. You can swap the projector with the Bosch e46 replica found at TRS. Unfortunately the lights do need to be opened to do so as the factory shroud slides on the lense holder. It is however a direct, no messing around bolt in swap.
Took these when I was at TRS looking for a replacement projector.
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
