This thread is specific to the OEM hood, which is aluminum so I assumed you meant  you are going to add a factory ram air hood. And I would definitely doublecheck because the SUV grill and headlights may not line up with the truck hoods. You can double check that by looking at the part numbers on the aftermarket fiberglass ram air hoods.
Edited by EXSlider400
Yeah I've looked for OEM, I'd prefer doing that but then the body shop said to specifically look for fiberglass that it's easier to shave down/add to if needed. But RK Sport makes these ram air hoods for 1500s and then 25/3500s!! Which those are fiberglass,  probably one of the next additions to the truck so I'll see how it goes!!?
I think the only way your going to get a ram air hood on that Tahoe is aftermarket, haven't see any tahoe's coming off the showroom floor with ram air... pretty sure the 2500 hood doesnt fit your Tahoe lol... probably could find alot more in the suburban and Tahoe forums
I love the look of the 2017 chev ram air hood on the diesels, I have a 2016 GMC 2500 denali diesel and I want that look on my P.U. I know its not a direct bolt on but is there any body men out there that can tell me if the hood scoop part off the 2017 chev can be installed onto the 2016 GMC hood ? air system doesn't need to work for the 2016. if so what kind of hours are involved? TIA.
I don't think the Chevy hood would ever look quite right unless you go to the Chevy front end (lights/grill). The 2017 GMC 2500s have the hood too. Direct bolt on. I put the 2017 GMC hood on my 2015. If you want it fully functional, it is around $1200. I had mine painted to match my truck for another $350. Total was $1550. You will need a VIN from a 2017 to order the parts online, most places require the VIN to make sure it fits. I used a VIN from Ebay :)
Do you know how the chrome comes of the inlet? Thinking about putting lights inside.
  • 6 months later...
Most places ASK for the VIN to "ensure" it fits, but don't require it. You just have to pay return shipping if you order something without the VIN to verify, and it ends up not fitting.
    • Looks tight. Not a lot of working room. Hows yous knuckles?
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
