jim larson Posted January 26, 2017 Posted January 26, 2017 Is it possible to add/replace an interior or an exterior self dimming mirror to a 2014-2017 LT similar to what is standard on the LTZ? Thanks
pgamboa Posted January 27, 2017 Posted January 27, 2017 (edited) Is it possible to add/replace an interior or an exterior self dimming mirror to a 2014-2017 LT similar to what is standard on the LTZ? Thanks Hey There. Yes, this is possible. I've done them myself. The Inside Rearview Mirror thread where I posted the "How to" is here: http://www.gm-trucks.com/forums/topic/192050-a10-inside-rearview-auto-dimming-mirror-conversion-dd8/?hl=a10+inside If you also want the dimming to occur on the Driver's Side Mirror, you'll have to upgrade your DL8 Mirror to DL3 Mirrors. Here is my thread for that. http://www.gm-trucks.com/forums/topic/190736-2016-silverado-lt-dl8-to-dl3-mirror-conversion-finally-complete-3/page-4?hl=dl8+to+dl3+conversion&do=findComment&comment=1900660 I have also made it easier for the DL8 to DL3 upgrade and make it Plug and Play with a custom harness that I build. Here is the thread for that. http://www.gm-trucks.com/forums/topic/196569-fs2014-silveradosierra-custom-plug-and-play-harness-for-dl8-to-dl3/?hl=dl8+to+dl3+conversion&do=findComment&comment=1923331 Edited January 27, 2017 by pgamboa 1
jim larson Posted January 28, 2017 Author Posted January 28, 2017 I have a 2014 Lt silverado 1500 with the standard mirrors (no tow Mirrors), will this work on my truck? So all I have to do is buy your harness or do I also have to buy a new set of mirrors?
cbrsilv15 Posted January 28, 2017 Posted January 28, 2017 To convert your mirrors to the DL3 power folding mirrors, you'll need to buy the mirrors, correct powerfold switch and the harnesses from Pgamboa to make them work. There is a known issue with the puddle lamps not having 12v from the BCM on the 14's though. Mine does it, but I will do the diode mod here when I get it. 2
pgamboa Posted January 28, 2017 Posted January 28, 2017 (edited) Exactly what cbrsilv15 said... Jim, also keep in mind that in order to get auto dim on the driver's side mirror, it is dependent on having the auto dim rear view mirror AND the circuits required the rear view mirror to pass the auto dim circuits to the driver side. When the rear view mirrors auto dim activates, it sends that single to the driver side mirror. My harness will have the auto dim circuits pinned (since I am unwrapping them anyway for the lighting circuits) but you have to complete the mod for the rear view mirror to get them to activate. Also - I would need a photo of the door connector (the side that goes into the body) to verify what pins you have/don't have. Sent from my iPhone using Tapatalk Edited January 28, 2017 by pgamboa
sk Posted January 30, 2017 Posted January 30, 2017 I have a 2014 Lt silverado 1500 with the standard mirrors (no tow Mirrors), will this work on my truck? So all I have to do is buy your harness or do I also have to buy a new set of mirrors? If you are talking about changing ALL the mirrors you will need pgamboa's harnesses. If you only want to change the interior mirror to auto-dim and keep you existing outside mirrors "as-is" just follow his first link. There are also instructions on other forums that just pull a power and ground from the overhead console.
DES2016LT Posted April 23, 2019 Posted April 23, 2019 Hello, I have a 2016 Silverado LT I bought last Aug. Soon as i got it home I ordered a auto dimming rear view mirror thinking it was plug and play. When i saw it wasn't dimming I started to do some reading. Ran across all this info on it. I'd like to use the rear view mirror but all the links above comes back to this page. I really don't care about the outside mirrors. Also I don't see how or where to buy a wiring harness if i need one. thanks
johnhankel Posted April 23, 2019 Posted April 23, 2019 Send pgamboa a message and he will hook you up. I had no desire to change the outside mirrors, so he made me a wiring harness to add the inside mirror and get the reverse disable working. Works great. I will warn you the wire you need to land in the X61 box is a real pain to get in there. Sent from my iPhone using Tapatalk
Blairs10 Posted February 16, 2021 Posted February 16, 2021 On 1/27/2017 at 5:29 PM, pgamboa said: Hey There. Yes, this is possible. I've done them myself. The Inside Rearview Mirror thread where I posted the "How to" is here: http://www.gm-trucks.com/forums/topic/192050-a10-inside-rearview-auto-dimming-mirror-conversion-dd8/?hl=a10+inside If you also want the dimming to occur on the Driver's Side Mirror, you'll have to upgrade your DL8 Mirror to DL3 Mirrors. Here is my thread for that. http://www.gm-trucks.com/forums/topic/190736-2016-silverado-lt-dl8-to-dl3-mirror-conversion-finally-complete-3/page-4?hl=dl8+to+dl3+conversion&do=findComment&comment=1900660 I have also made it easier for the DL8 to DL3 upgrade and make it Plug and Play with a custom harness that I build. Here is the thread for that. http://www.gm-trucks.com/forums/topic/196569-fs2014-silveradosierra-custom-plug-and-play-harness-for-dl8-to-dl3/?hl=dl8+to+dl3+conversion&do=findComment&comment=1923331 Why can't I follow your link to the first one?
pgamboa Posted February 22, 2021 Posted February 22, 2021 Do the tow mirrors auto dim?No tow mirror on the marker dims... that I’m aware of. Sent from my iPhone using Tapatalk
Aarons Posted April 21, 2021 Posted April 21, 2021 I have a 2015 gmc sierra 1500 with regular mirrors but dl3 auto dimming and power fold along with many other options is it possible to remove the auto dimming option I can't find mirrors with all of these options
mmmikkke Posted October 11, 2021 Posted October 11, 2021 On 2/15/2021 at 7:53 PM, Blairs10 said: Why can't I follow your link to the first one? corrected link:
