Color matching front and rear bumper
ryanhardy
Would love to color match the front and rear bumper on my truck, main thing I'm wondering
-has anyone on here done it before?
-about how much did it cost/ has it held up?
-would it be more cost beneficial to just buy one already painted from the factory?
-I thought I saw a thread about someone with a high country wanting to trade for chrome bumpers. if that person's still out there I'd love to!
I was quoted $600 to color match my grill, front and rear bumpers. With a wrap not paint. I kept it stock for now.
So a second question for this topic... talked with one of my buddies that paints at a local collision shop and he said it would be a bad idea as when you paint over chrome it chips badly.... I feel like I've seen other people paint their chrome bumpers and have had no issues with it.... any ideas or suggestions?
I think the problem w/ painting chrome is that the surface is too smooth compared to bare metal (before priming).
you would be better off on ordering them from the dealer or a junk yard, and if you have the sensors in the chrome ones, make sure you get the same ones from a salvage yard if you go that route. Me personally, I would just order them from the factory so I know everything matches up
ordering them from a dealer would more than double the price, which is why I'm asking about painting.... and these trucks are way too new to be in any of the salvage yards near me
Wrap the chrome with white. You will hate paint, it's like a sand blaster up there, wrap white and it will look great, stuff will bounce off and it's easy to remove. You may not have to remove the bumper, that would be great but you can make this look better than paint.
I had my chrome bumpers sand blasted and primer powdercated , then painted at local body shop no issues with paint peeling or easily chipped
I mentioned this to a friend about trying to paint chrome. He said trying epoxy primer & paint may offer better adherance & durability.
Vinyal wrap itt you will not be disappointed at all, 3 solid winters of great north woods weather taking a beating snow salt dirt rock chips etc..
Probably wrap or powder coat is the best option even with the stock gm color matched bumpers get chipped up pretty quick from road debris n what not , going to pull mine off maybe in the summer and have it re-done
Sent from my SM-G930T using Tapatalk
My friend owns a body shop and quoted me a new Denali bumper with fog lights, bezels and paint it to match the truck for around $1800.00
The bumper shell is approx $1000.00 primered, paint is approx $350.00, fog lights and bezels approx $160.00 and labor.
They have complete bumpers on ebay but there around $1500.00 plus shipping and have some paint damage on them....
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
