Why is it that my key FOB can reach my 2017 LTZ-Z71 Silverado Midnight 1500, but when I try to remote start my truck it does not seem to reach.
Example: I Push the lock Icon once (lights flash), hold down the Remote start button, and hold for approximately four seconds (lights flash again), and it will start, SOMETIMES. Sometimes it does not start, but the lights will flash when I hit the lock button...
Is this common? Seem like if the FOB can reach the truck, it will do any function it should.
Try holding the key fob under your chin and press the start button I heard about this along time ago and it works trust me I do it with mine all the time when the truck is to far away from the fob to get a signal, hold it under your chin touching the bottom and it increases the range of the signal iam not BSing you. If you don't believe search it on Google.
Yeah, I know that one from the '80's when I was a kid. but, thanks though. I was hoping that I could get an answer that would solve why the range sucks so bad. I read back in to 2014 range and found that some people have gone with Viper, Compustar, or even went with a 2016 battery, and doubled it up (don't sound correct to me). I would have though that over all of these years, they would have tried to knock out the aftermarket by improving themselves. The phone app is great, no doubt about it, but sometimes it's much quicker to use the key FOB...
I still don't understand why I can lock the truck, but not remote start it...
Edited by 6.2Midnight
Onstar app on your phone is an option, but doesn't really sound like what you're looking for.
Sounds like an issue with the truck not the fob if the lights flash with the rvs request.
I currently have a '17 rental while my '14 is in the body shop. I noticed that it doesn't rvs at times just like yours. I'm guessing their is an issue with the bcm as that is the module that is responsible for the rvs request.
Try your second fob to make sure it's not a fob issue just in case.
Edited by ChevyTech77
  • 4 years later...
Sorry to bring this back from the dead, but did you ever find a solution to your problem? I have the exact same issue on my 2015 LT Silverado. I could lock/ unlock it from across a Walmart parking lot, but the remote start is a different story. I’ve got 3 fobs, 2 GM, 1 aftermarket, all with brand new ultimate lithium batteries, and the range flat out sucks. I’m thinking mine could be a loose wire at the RCDLR module that receives the signals then sends request to BCM.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 845 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
