I got the new cable to today and installed it.  Everything is back to working order.   Thanks @67firebird455 for making the posting that got me started on the trail to solving my problem!  This is the cable I used that fixed the problem.
Flat Ribbon cable 40 Pin 0.5mm Pitch 200mm long FFC/FPC Reverse Direction (see picture below)
https://www.ebay.com/itm/Flat-Ribbon-cable-40-Pin-0-5mm-Pitch-200mm-long-FFC-FPC-Reverse-Direct-1pc/112412362149?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
So $3.50 + shipping and the problem is solved.  I actually bought a couple of them just in case I need to do this again in the future.   Anyone else looking to do this, I still recommend that you get a good pry tool for opening up the screen.  It's not hard to open, but there are a lot of tabs.  Since I've done this a couple times now I've broken 3 or 4 tabs myself, but there are plenty of them on the case so missing a few doesn't cause any issues and everything still snaps back together nicely.
Hope my added info actually helps some of you out. I'll also confirm that this takes about 30 - 45 minutes to complete at the most.
Fantastic.  Thanks a lot Mark!  Glad you got it all sorted out buddy!
Now... if I could get someone to assist me in eliminating the magneride on my '15 Denali, I'd be grateful! ;)
Thank you for the info just took the player down and reversed the cable as in the previous post and it’s working again. If you are the least bit mechanically inclined it’s an easy fix. Less than 30 mins. Thanks again kept me from being overcharged by GM.
Fantastic!  Glad the post helped you out!
Did the reverse yesterday also and it is back working fine. The parts number is now superseded so hopefully it's upgraded on newer models
On 12/9/2017 at 2:02 PM, 67firebird455 said:
I did, but no specifics on width/pitch/length or anything.  I should have measured and really taken a look at mine when I had it apart but was in a dang hurry because we were leaving on a 6-hour trip up to the time share and didn't want all three kids in the third row fighting. hahaha
I have a feeling this would work https://www.ebay.com/itm/Flat-Ribbon-cable-40-Pin-0-5mm-Pitch-200mm-long-FFC-FPC-Reverse-Direct-1pc/112412362149?hash=item1a2c4c85a5:g:EMUAAOSw-K9ZHqwL
The link has been updated to  https://www.ebay.com/p/Flat-Ribbon-Cable-40-Pin-0-5mm-Pitch-200mm-Long-Ffc-fpc-Reverse-Direct-1pc/18013512683
Excellent thread. I have the exact same issue with my 2015 Tahoe. The screen went black yesterday and won’t turn on (2nd screen similar to everyone’s discription). I would like to trouble shoot this myself without dealer involvement (however I’m not mechanically inclined at all). Any tips on lessons learned or what I should know before getting started? I have a very long road trip with the family beginning tomorrow and having the rear entertainment system working would be a blessing :) Thanks for any advice that you may provide.
Having same issue with 2015 Suburban. 2nd row dvd not playing but 3rd works fine. So do you all think if I order that ribbon with link posted that should do the trick?
It was the ribbon posted above. Literally a $5 fix. Great thread that will save everyone a lot of headache and money. The ribbon fixed my 2015 Tahoe issue this past weekend.
Thanks for the feedback!  I ordered it a little while ago and hope to be able to fix it this weekend as well!  Was it easy to do like previous posters said?
It took some patience. I’m assuming that I’m not as handy as some of these guys. Carve out about an hour and you will fix the issue.
Thanks to whomever posted this info!  Ordered from the link and hubby fixed it today!!
It may be 2 seperate issues. I would fix the ribbon first as it is an easy inexpensive fix. Follow the pictures in this thread and take your time. I would also do a Google search for how to release a stuck DVD. Good luck.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
