How did you tie your intake in? Just get a new one?
I had a Airaid MIT... but be sure to get a 6.2 (it's a 4" silicone coupler). or order a MIT for a 6.2L
RT
If I were to do this it takes times to get the tune from black bear. Is it possible to just do the swap and wait a few days for the tune? Of does the tune have to be on it right when I do the swap ?
Yeah so don't fvck with me!!!! Hahaaaa.....JK! I threw some carpet and cardboard over the engine and crawed my fat ass over it all. BTW 6'
RT
  • Haha 1
I'm going to order the intake f4om eBay. So any intake that says l86 is fine?
Damn why did I have to see this thread! For the guys that have done this did you notice the throttle response? Has anyone ported the 6.2 manifold? When I had my z06 the stock manifold as well as the fast I installed after both were kinda rough inside. Not fully smooth. Had steps. Ended up porting them and cleaning with a 500-1000 grit paper. Was very smooth in the end. Haven't seen one of these manifolds in person so not sure if these will need some cleaning up.
Time to spend some more money
Yes to better throttle response even before tune. I put the Katech ported tb on mine and I love it.
  • 2 years later...
Digging up an old thread, but does anyone have torque specs for the swap?
I also have the Airaid tube, sounds like I need a new coupling, anyone have a part number?
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 522 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
