LED Light Question
White Sierra, not sure if it is just the led bulb, but I did get an OnStar message on my truck and the wives Tahoe. the led bulb will only work in one direction on the license plate bulbs unlike a traditional bulb, that does not make a difference which way it goes into the socket. and, the best part is, the OnStar message never goes away.
Sounds petty, but I hate those messages... so much so that I may not change the lights because of them haha.
  • Replies 32
It doesn't pop up on the truck screen. You just get a monthly email from onstar
And technically there's nothing at all wrong with the lights, correct?
A resistor is only required when you are using the leds as turn signals. Just replacing the reverse and cargo bulbs won't do anything.
Can an SLE use LED kits with the DRL?
Yes, I believe they can. I just spoke with a forum member who used the 9006 bulbs in his Sierra. The DRL's work in the Silverado with no modifications using the OPT7's. I'm pretty sure the Sierra DRL system works the same way. Only half of the LED's light up for the DRL function.
The big difference is that the Silverado uses a 4 bulb system and the Sierra only 2. The guy I talked to said that he had ditched the LED's after a time because they continued to lose brightness. He went back to HID's.
There's a ton of info on LED headlights for Silverado and almost none for Sierra.
White Sierra, I have the factory GM LED's on my Denali, they are just incredible. I would say just do the conversion like others have on here, get the harness and get some OEM GMC lamps. believe me its worth it.
little background, I worked for Mercedes Benz for over 6 years I have seen lots of lighting technology including working on them, GM's new LED's where long over due.
btw the GMC headlamps are not serviceable, the only lights on my truck that can be swapped are 2x reverse lamps, 2x cargo & 1x 3rd brake lamp, and 2x license plate, 7 bulbs total. I swapped all to JDM & osram/sylvania
steer clear of Phillips on new GMC led tail lamps they dont work well IMO, GMC reflector is 1 of the reason & Phillips have lower luman/s output compared to other LEDS.
Revsere lamp = https://www.amazon.com/JDM-ASTAR-Extremely-Reverse-Parking/dp/B00MUF1APW/ref=sr_1_3?ie=UTF8&qid=1486757958&sr=8-3&keywords=JDM+912
^ those made a HUGE difference in reverse lights, completely destroyed the Phillips, people know when your in reverse.
Cargo & 3rd brake = https://www.amazon.com/JDM-ASTAR-Extremely-360-Degree-Chipsets/dp/B01F2MUPZ0/ref=au_as_r?_encoding=UTF8&Make=GMC%7C48&Model=Sierra%201500%7C548&Year=2016%7C2016&ie=UTF8&n=15684181&s=automotive&vehicleId=2&vehicleType=automotive
^Cargo lights get a huge boost in output with these, just dont be behind the truck when someone flips them on LOL.
License plate = https://www.amazon.com/dp/B01A77TXNK?th=1
^ perfect color and just the right amount of light since everything else was LED.
Thanks for your input! That helps a ton!
I would love to swap out the headlights with these OEMs - http://www.gen5diy.com/GMC/Sierra/Lighting-and-Harnesses2/Headlights/GMC-SLT-LED-HEADLIGHTS/, but they are sooo expensive! Are you saying there is not LED kit that would work well on my truck without spending the $1300 for the OEM?
nothing. lights are a very "white" hue. the factory led's in my 2016 are so much better than the lights I had in my 2014. both trucks were/are LTZ Z71 models. literally "night and day" difference.
I am not familiar with the 2014-2015 OEM lights except for all the complaints on how bad they are. I believe you can install some high powered LED's to replace your current halogen. I would not go with anything less than 40 watts per LED for headlamps, most of the time it will say 80 watts total like on amazon etc...
2016+ LED headlights are not serviceable, they are completely sealed from a OEM stand point. example if they fail and dealer will replace the entire assy...
You're 2014-2015 will allow for aftermarket bulbs/LED/HID kits
    C. Hart
    C. Hart
  • Who's Online   4 Members, 1 Anonymous, 608 Guests (See full list)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
