Is 20x9 +12 correct for me?
6.2Midnight
I wanted to run the stock 20" CK-156 rims, but if I do, I was told I would need a 7/8 wheel adapter (not spacer) because I will also be adding a 2" level up front only. Sound correct? I really don't want to have to run an adapter, and also have the front tires stick out wider than the rears.
So, I started to look at aftermarket rims. Now I am thinking of going with the 20" FUEL Hostage rim, with a 2" front level only, I was told that if I run Duratrac, or TKO's that are 285/60-R-20 I will need to go with a 20x9 +12mm offset rim. Sound correct?
If not, what has been run successfully, that did not rub at all, or not very much at all?
This is what I came up with, it just cannot show the 2" lift...
https://tiresize.com/comparison/
https://tiresize.com/wheel-offset-calculator/
