Fuel Tank Upgrade
jbgrizzler
Picked up new Sierra SLT, 6.2 lt, max Tow package with 6.6' box. Filled her up for the first time today and to my surprise she only took 75Lt / 20 gal from empty!!!!. I had asked for a large tank option early in the discussions only to be told it was not an option.... but I expected a 98 lt (26 gal) s per my 2007 and other newer GM's I had been in.
Why would GM think a 75 lt tank would work for true truck buyers/users! Especially with a 6.2 lt and 6.6' box. I'm a extremely disappointed. Does anyone know if there are larger aftermarket gas tanks for these trucks available or if there is even room to put a larger tank by chance. Had I known I'm not convinced I would have purchased although I am a GM guy at heart! I'm in the Toronto Ontario area.
Ford can put a 120 or 135lt tank... why can't GM!
Not in a good place right now
  • Replies 33
It's 26 gallons, the gas gauge will show empty fairly early. 8ft bed has the larger tank. Unfortunately GM doesn't offer a tank upgrade like ford does.
Wouldn't you just be carrying more weight around with a larger tank? With the increased fuel economy of these newer engines, you would probably need to stop on a long trip to stretch or use the bathroom anyway.
Sent from my SM-G935V using Tapatalk
It's not 26 gallons. Look it up. Even on the GM website they do not advertise it - cause they know some guys won't touch'm! It's 20. You own one? What year/model/ box? Dealership confirmed. That's why I'm looking to see if anyone knows of any aftermarket tanks for 1500. They have some for 2500 and 3500 I've seen but not 1500. As for carrying weigt - it's a truck. If I was worried about that I wouldn't have bought a truck.
My 2016 double cab 6.6 bed is 26 gallons. Says so on the spec sheet, and I have put 25+ gallons in when running on empty
I have a 14 CC. According to the gas pumps around here, I have put in as much as 24-25 gallons at a time. And with my typical driving habits average about 450-500 miles per tank. Im not saying I wouldn't like to have a 30 gallon tank or more, but the "26" is plenty for needs. My last truck was a heavily modified Nissan Frontier. It only had a 21 gal tank, which would barely get 300 miles from a tank (under powered 4.0 v6). So I'm very happy w the range of the Silverado!
26 gallon tank under your truck... drive the truck till your low fuel light comes on.. drive to the pump and watch the gallons.. should put 23-25 gallons in..
I agree with the OP, I came from a 2012 f150 with a 135L tank (Canada) and now have 95L tank on my 2017 GMC Sierra. Is it a deal breaker, hell no ! It's probably my only complaints with the new truck. I did grow to love the big tank but I'll learn to live without for the other benefits that GM has over Ford.
I've also put more than 20 gallons in mine. 2015 CCSB. The manual also agrees. 6fc100dcab5ad9b372ac835ad12cd7eb.jpg
There is the 34 gal tank, that comes on the reg cab, 8 foot box truck, 1500 model.
The question is; and no body has ever been able to answer this, is will it fit under the crew cab truck, with long or short box???
OP.... You should be the one to try it out, and let us Know ?
Its will not fit. Tank will mount in the same location but the tank will hit the rear end.. maybe a crew cab long bed
My gauge was just on the low side of the 1/4 line (actually touching it) when I filled it up.....took 19.? gal....almost 20.
Same as my 2006 Sierra was.....26gal
Wow. This is nuts. Mine's a 2017. Pulled the manual and it states 26 gal - 98lt. I'm gonna drive this thing to near dry again and film the whole filling process. Swear it only takes 75 -77 lt from empty. Hope I'm wrong but only filled it once. I'll post. FYI - my manual also states 98lt tank. Hope they didn't install the wrong tank! Fixable but a pain in the ass!
It normally takes 22 gallons to fill mine up. I guess they gave us a large cushion in case you have a brain fart or something.
Low fuel light usually comes on for me around 21 gallons
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
