Did some research last week when I ordered my Bilstein shocks and it appears there was never a stabilizer put on these trucks. The mount and holes are there just no shock.
Ordered the Bilstein stabilizer for the truck along with then shocks. Steering stabalizer came with all the necessary hardware for install. I Just put it in. Took 10 min. Figured I would share my experiance for anyone looking for a cheap upgrade
$75-$90
There are other options for 40-60$. Rough country, Monroe ex. ex.
Edited by mattymax
Good to know for guys that want oem
Yeah, not the best option, but at the time nobody offered aftermarket replacements since leaving off the stabilizer was a 2011/2012 thing.
I'd probably buy a Bilstien if I was to replace mine.
The 2011+up HD trucks are designed and intended to not have a steering stabilizer.
#PIT5052F: Steering Wheel Vibration Or Customers Looking To Add Steering Stabilizer - (Jun 14, 2016)
Condition/Concern
Steering wheel vibration or customers looking to add steering stabilizer for the Chevrolet Silverado and GMC Sierra HD 2500/3500 models.
Note: On 2011 trucks with a vibrations felt in the steering wheel, follow published SI diagnostics. The latest version of PI0650 may be helpful in diagnosing this condition.
Recommendation/Instructions
The 2500/3500 HD trucks are not built with a steering stabilizer.
A steering stabilizer is listed in the parts catalog group 6.865 (steering linkage shock absorber) and is available, but is not intended to address vibrations or brake pulsations.
This part can be added, but is not intended to be used for a warranty repair.
Additional information: The 2500/3500 HD's are specifically built without a Steering Dampener Shock.
The explanation below can be used to give a more detailed description of how the 2500/3500 HD steering system functions, with respect to road input.
Steering damper's predominate influence is on large heavy impacts encountered during more extreme off road events.
For smaller chatter/bump surfaces, the steering damper does not see high enough rod velocity to generate resistance force.
For these situations, there is more mounting bushing compression than anything else.
The 2011-14 model year 2500/3500 HD steering gear system features the same knuckle steering arm to pitman arm length ratio as the previous (2010 and older) HD model, but the steering gear piston diameter is larger and capable of higher pressure, which creates more viscous damping in the 2011-14 model year 2500/3500 HD steering gear than the previous (2010 and older) HD model steering gears.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed
I put a rough country stabilizer on my 2011 2500hd. It helped reduce some of the shake I have in my front end. Some of it is due to rusted rotors and calipers. And some Is the pitman arm bushing in the center link is worn out.
While I don't disagree, it makes a wonderful improvement in rough road feel through the steering wheel.
So why not fix the issues instead of band aiding them with a stabilizer?
I am planning too. I have new front rotors, calipers and pads waiting to go on. I have to find the time to do them. Also planning to order the upgraded center link and do away with the bushing as well as new pitman arm and idler arm. It's not cheap.
Well after putting a few miles on the truck is seriously tracking to the right. I understand it's a gas filled shock but is this normal ? Should I try a different brand shock ? Or totally do away with it. It's tracking so bad I constantly have to redirect it back to the left.
I have the same one on my 08' Ford F-350 without any tracking issue.
I heard that before about gas filled stabilizer shocks doing that.
I've often wondered if the gas charged shocks were meant to be used in pairs to counteract each other?
Is the oem gas filled ? rancho ? Rough country ? I know a lot of guys that use these with no complaints.
This is very obvious pull to the right. Driving at 40 mph, you have to constantly redirect to the left.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
