3D Printer to the rescue / AFE CAI
Well I ordered an AFE intake for my 2017 6.2L Denali. When it arrived i realized they had shipped the wrong one its for the 2009-2013 trucks.
We went back and forth for a couple weeks trying to find a solution as it was bought on eBay, shipped across border, etc.
It ended in them offering to refund me the total cost minus shipping. I agreed.
(Figured Id sell it locally and make that $ back)
In the meantime I picked up a K&N system for my truck locally so there was no confusion (also the only thing I could find local). I didn't love the K&N setup to be honest. It was loud that's for sure but the open box, using the hood, etc ... I don't know I just don't love it.
So I went back to my AFE setup and decided to see what wouldn't fit and what did fit to see if maybe I could make it work.
Incompatible Differences:
1) MAF sensor port doesn't work at all with 2017.
2) missing one breather port for the crank case
3) boot that goes onto the throttle body is the wrong size (throttle body side)
4) throttle body on the 09-13 had a slightly different angle but not a huge deal.
Went to the hardware store picked up a brass barb fitting, drilled the proper size hole, heat up the fitting & thread into PVC tube = #2 solved
Boot from K&N system fixed 3&4.
This is the 14-17 MAF port that I needed.
And this is the 09-14 MAF port on the kit that they shipped accidentally.
Went into my office took about an 20 mins in my design software and a few revisions later I ended up with this. 81191a6245ac644f4bb889844683a306.jpg
Dropped that into Simplify3D and made a sample out of ABS.
Trimmed the opening a little, then used some closed cell PVC weatherstripping and some stainless gear I had laying around and strapped her in, perfect fit!
Hooked everything back up, double checked all connections, attached the negative battery cable, fired her up.
Runs fantastic (seems a little stronger in the pulls than the K&N but that may all be in my head. Still sounds great but a little more tame / luxurious / refined than the K&N due to the closed box design I think.
Let me know what you guys think. Love it / hate it / anywhere in the middle.
Cheers,
BDC
  • Replies 33
Love it for the shear fact of the creativity in creating a solution to the problem! Well done!
Thanks guys !! Yeah I was a little pissed at first then I remembered I own a 3D printer and I'm not half bad with the design software ha ha ha
Edit: and it ended up being pretty cheap ;) lol
That's really, really cool! I'm a total nerd and love tech innovation like this. What 3d printer amd software are you using?
Sent from my SM-G930V using Tapatalk
Slicing with S3D , designing with solid works, Lulzbot Taz 5.5 (it's a 5 upgraded to a 6 minus the auto level as I don't want it lol)
Thanks man !! 3D printers make everything possible pretty much !!
I'm pretty excited to put some Km's / miles on it and see how it does!
If you can print an AR lower that bracket will do great lol.
We don't have guys like you guys up here in Canada but I just looked up 3D printed AR lower .. pretty cool !!!
Yeah I'm pretty sure it will be good! I printed it out of ABS, but if I have any issues with it I'll print it in nylon next.
I love to see problem solving. Looks great! Maybe you could go ahead and print me a supercharger
Sent from my E6810 using Tapatalk
How big of a 3D printer is it? How long did it take to run?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
