Title pretty much says it all. I just bought a new 2017 Sierra All Terrain with the DVD system and I want to remove it. I don't have kids, so it will never get used!! Would be better off buying new headrests and selling the system.
I searched online and found the part number, not sure it is 100% accurate. Dealer installed GM DVD system, not aftermarket, in a 2017 Sierra.
I want the instructions so I can make sure I get everything, and don't take to much!!
Thanks
Edited by FAST380
Thanks
Did you ever figure this out?
I have the install instructions. I can email a PDF to you. PM me.
Edited by Justin101714
Cool!! I just sent you a PM with my email address.
Thank you!!
If you want to sell it let me know.
I do want to sell it. I have a 2017 Sierra SLT All Terrain, the headrest are black leather (probably vinyl) with red stitching. The DVD systems are brand new, I haven't even taken the plastic off them yet. I don't have kids and only use the truck on weekends. I will sell they system complete with headrest and shipping for $1300, or if you have the same headrest, I will take yours and $1100. Send me an IM if interested.
Scott
  • 4 years later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
