On 4/11/2018 at 4:58 PM, JohnnyCruz said:
Almost done; I received this picture today from the shop. I'll take more pictures once I pick it up.
did you have to change the lights harness or the same one is good for the change of lights .??    can i get the list of parts # so I could try to do mines that way, looks awesome by the way.....
  • 4 months later...
On 4/10/2019 at 11:19 PM, Mileguru said:
Any significant improvement to the performance?
I already had a cold air intake and the. Borla exhaust when i installed all this , not sure if there were any real gains but i am very happy with it, i know im late with my response
On 6/24/2019 at 7:14 PM, SirenRed16 said:
This guy did it also and said it took a lot of work to make it fit24448c6bc0c53e235de7b9d8fd4af116.jpgba5d67ce975926b456e11eec2df85f51.jpg
anymore specific details on this hood swap?
No but but I'm pretty sure I recall him saying it needed a lot of custom fab work to make it fit properly.. it's not like the GMC, they seem to be a bit easier
10 hours ago, Sergio Rodriguez said:
So you bought all parts online from gmdirect? And also what color did  the hood came in?
I bought mine online and picked it up local. If you can pick it up instead of ship it, you will saves hundreds of dollars. If you buy all the parts at once (hood, insulation, tuning, etc), shipping was over $250. I ended up buying them and picking them up. I bought everything from Quirkparts.com, they had a local warehouse to me.
The hood ships primed black.
On 4/21/2020 at 9:26 AM, Sergio Rodriguez said:
And you order everything from a 2017 2500 HD? I have a 2014 Gmc 1500 And I’m trying to swap the hood
there is a different grill on the 2500HD. I already have an 2500HD, so I only needed the hood, insulator, the trim and the plastic piping to the air box. Plus the various nuts/bolts. You will need the HD hinges as well.
There is a post on putting the HD hood on the 1500 and includes the part numbers. Here is the link:
Do any on you know the parts list for the internal components in the hood? (2017 Silverado 2500hd)  I already have the hood and intake vent but Need to know the quanity for all the other parts on the inside so I can order.
by the way....this is going on a 2016 Silverado 2500HD. Thanks!
Do you know what the weight difference is? Notice any performance benefit because of the colder airflow or is it purely aesthetic with your truck.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,827 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
