Catch Can
Is the jury in yet on the subject of catch cans? Valid piece of equipment or snake oil? At any rate, it seems the sort of thing the dealers might be embracing, just like VIN etching or fabric protection. I can just hear the pitch: "Keep your engine running cleaner, smoother, longer! Ask about our Catch Can service - available for only $895". Are they missing the boat or do they already have enough ways to remove what's in your pocket?
There's 59 million threads on this. Some say yes. Some say meh. I bought one. I'm installing it later today. I'm sure it's not needed but it's good to have.
Devil's advocate would say maybe the mist in the engine is by design - maybe a catch can removing it is not only unnecessary but detrimental........... GM did do a little testing on GDI engines U know..........
Hard to figure blow-by being a design feature. But, I'm far from being an automotive engineer. I tend to think that, if it's such a wonderful thing, the manufacturer and/or dealer would be on it. As always, putting too much creedence in what a vendor has to say might not be in your best interest.
I bought one. They aren't expensive I'm sure it'll help some
As far as deductive reasoning goes, the "It doesn't hurt anything (except your bank account)" argument would seem the most efficacious. The same reasoning might be applied to support painting pink polka dots all over your truck (also not expensive). Impeccable logic. But, common sense good idea?
To many big words for me to comprehend.
To make this easier. There is no yes or no. You either want it or you don't.
Will it hurt? No.
Will it hurt? No.
Just out of curiosity, which words are giving you the most trouble?
The issue is whether you want it because it's a good idea or because you've been led to believe so by the marketing.
Saying it won't hurt validates my argument.
I think it's a good idea. But that's my opinion. All of my buddies with 99-up motors have them and wear by them. The shit that comes out of them is a trip. So for me after seeing them needing them. I'm sold
if you look at the Camaro forums, theres a lot of info there...I like the ones that the bottom of the can screws off, for easier cleaning, compared to the petcock/hose on the bottom of the can...
I the the Apex Speed and the Elite are 2 good ones...
OP, its a catch can, basic fuction is to catch/trap PCV vapors, oil mist, water vapor, I can say yes! it works. I have ran my can since I have owned the truck for 11months & 11days and 19xx miles so far, 1 oil change due b/c of time, I caught both oil & water vapor. I chose a larger can for improved surface area. Elite Ultra 2x something...
However IMO, I might move my location to front grille area, the catch can gets very warm under the hood over aux battery location, if the idea is to turn liquid vapor/mist back to a liquid its best to keep the can cooler even with the interior mesh and tubes.
This
I bought the Moroso catch can, it's amazing what nasty stuff comes out of it. My plan is a remote resiviour below and leave the drain open. All air tight of course.
There is the issue of warranty being voided due to installation of mod. Has anyone looked into that?
Before you take it in to the dealer just pull if off. Takes 5 minutes
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
