Towing Mirror Questions
My 2014 1500 LT currently has the small heated and power mirrors. Does anyone know if I upgrade to tow mirrors that also have the integrated turn signals will they be plug and play or do I get to fiddle with wiring? And by fiddle I mean just have turn signals that don't work.. lol
This should hopefully answer all your questions.
It is a lengthy one, but covers almost everything there is to know about upgrading your mirrors.
http://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-mirrors-explained/
Wow, very detailed!
So no turn signals for me.. Guess it's time to trade her in on a new model! Lol
2014 will have the most challenge as GM didn't include the tow mirror circuits in the door hinge connector. There are 3 circuits for the lighting portion. Turn, Cargo, and Running lights. In almost every 2014 owner I've worked with, so far, all of them had lighting circuits missing. I think some had Turn signal present, but not the others.
Let me know if I can help in any other way.
You can do what I did on my 2wt if you're brave enough.
Sent from my LG-H918 using Tapatalk
  • 4 weeks later...
kinda old thread but did you figure this out?
All of the standard features work: heat and adjustments. But the extras don't, running lights, turn signals, and flood lamps.
That being said pgamboa sells a wiring harness that I plan on getting down the road that should solve those issues.
There are two parts to this issue. 1.) Yes - My harness will help make these work. 2.) With 2014 and some early 2015, there will be a need for the RZY Jumper Harness that will complete the circuits from the door connector - going inside the cabin and to their appropriate locations.
For all the detailed info and process, check my "Mirrors Explained" thread.
They're worth every penny. I love my signals, and Phil even showed my which wires for the puddle lamp diode mod.
