6.2L rumors and Final Order Date for Sierra 1500 Crew cab?
Just got this from a dealer today.
"There is talk of GM not offering 6.2 engines in nothing but the Denali for future models."
Anyone hear similar news or is this just unfounded chatter?
He also said, "What you are going to notice is less and less 6.2 liters available due to constraints. I wouldn't wait too long if the 6.2 is what you are after."
Not sure about this line either. If there were such constraints, not doubting that possibility for CA vehicles, why would that mean it would be available in only a Denali. That is contradicting info to me. Or perhaps it's just two separate possibilities of how things could come true.
Those statements were prompted when I asked what the Final Order Date is for the Sierra 1500 Crew Cab. Which I did not get an answer to my question.
Anyone know the Final Order Date for the Sierra Crew Cab as stated by GM?
Trying to scare you into buying now?
Ryan B.
Ryan B.
In part I agree. While I find how he stated things illogical, I can also speculate there being some truth. As in truth in changes, but not necessarily with what he said. If you make the 6.2 in a Denali only, then the Max Trailering Package will only be available in the 5.3l. So if that happens either the 5.3l is either getting a boast in power with the Max Trailering or GM is pushing people to tow with 2500 and up. Dealers and their rumors.
So does GM wait until the day before to announce the final order date? Geesh, post it already!
Salesmen will say anything to try to make a sell............. just laugh and keep shopping
Constraints are due to CAFE. DJ is wanting to kill off CAFE and let the free market rule what people buy. If that happens, it is 6.2L trucks for anyone that wants one.
Right, while the current administration seems to be on a mission to take us back to a galaxy far, far away a long time ago, that would ease some pressure on manufacturers to meet the next 25 years of standards set for trucks.
However, that is federal and where I live now has a higher set of standards and it will only get higher, as it will in a dozen other states following the higher than federal requirements.
Also, manufacturers know they need to look beyond 4 years of a president and see that this world is changing and vehicles will have to change with it. Sooner or later is the only question. With all of that said, getting rid of the 6.2l only make sense to me if they are coming out with a more powerful 5.3 or smaller, like Ford. The 6.2l only in a Denali sounds goofy, but ya never know.
P.S. I didn't know Dwayne "The Rock" Johnson (DJ) dislikes CAFE?
I gotta go buy some bubble wrap and put this 6.2 in storage! No dang telling what this "Rare Bird" will be worth a few years down the road...............
Oh yeah. I'm buying 5, just to tuck them away.
Its funny now, but in 20-30 years you may wish you did..
If only I had $300K for a lot of 5 and a place to store them, I surely would not be waiting for GM rebates to go up just for me to buy one. :nonod: So I can finally :driving: off the lot.
On a side note, turns out GM has stopped production of Pepperdust Metallic months before the final order date. Hmm, not sure why?
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
